Running in a team Orion Dynoed motor? Would you? >
Old 01-19-2005, 01:33 AM
MDL
Default Running in a team Orion Dynoed motor? Would you?
Just got myslef a Team Orion 27Turn Dynoed motor.
Would you run this in or would it be done at the plant?
MDl
MDL is offline
Old 01-22-2005, 02:38 AM
MDL
Can someone please give me an answer to this?
MDL
MDL is offline
Old 01-22-2005, 10:47 AM
Jack Smash's Avatar
Trader Rating: 35 (100%+)
Pull the brushes out and see if they are worn all the way across the face. If they aren't, the dyno numbers that came with the motor are worthless and you need to continue running in the motor until they are all the way seated. If they are are, plug it in and go.
Jack Smash is offline
Old 01-24-2005, 07:15 AM
Joe Pillars's Avatar
A dyno version Core stock motor has already been broke-in at the factory.
Joe Pillars is offline
Old 01-24-2005, 01:27 PM
MDL
Mate, this is what I thought.. I got it down there and it hadn't been run in :-(.
Well i can tell you that I won all my races with it any way lol
MDL
MDL is offline
Old 01-24-2005, 01:41 PM
If the motor had a dyno sheet with it, than the motor was ran.
Old 01-24-2005, 01:42 PM
Trader Rating: 22 (100%+)
Joe I think where alot of the problem is that the majority of the motors you buy (no matter whos they are) are never broken in all the way. They almost always still have serrations on them.
Bob Barry is offline
Old 01-26-2005, 08:31 AM
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
having serrations doesn't mean the motor isn't properly broken in. You need to make sure the brushes are fully seated. with 767s and my Orion Chrome stock ( yes, chrome stock ) I can seat my 767s and still have some serrations left.
If the brushes aren't fully seated, its not fully broken in. Seen plenty of MVP plus motors that aren't fully seated but you still get a dyno printout as well. As for Orion, not sure, but always check regardless of what anyone says.
Cain is offline
