Old 03-25-2012, 07:54 AM   #31
Trader Rating: 49 (100%+)
Originally Posted by Sean B. View Post
How about POS. That term seems more fitting.
How Savox and Spectrum continue to gain popularity is beyond me. People are willing to buy junk, just to save themselves 20 or 30 dollars on some of the most important pieces of equipment in their cars? Preposterous.
They're not bad servos and they work fine as long as you're not using certian combinations of electronics.
They work perfect in 1/8th nitro/electric.
I just don't want to change recievers or electronics. It will cost me more money to do that than to buy a couple different servos.
-Mike B. - TLR22 - Tekin - K.O propo
aradaiel is offline   Reply With Quote
Old 03-25-2012, 08:05 AM   #32
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
I've been running Savox servos for quite a while with no issues. I've got a 1257 and a 1258 both hooked to MMP's, one with an Airtronics radio and the other (I'm so embarassed...) with a Traxxas radio. Adjusting the steering endpoints so the servo wasn't overthrowing by a country mile helped eliminate the brown outs.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 03-25-2012, 07:40 PM   #33
I had the same problem with my SCTE and put a cap on, But that did'nt work so i spent the money and got a external BEC. Problem solved.
Love my Losi. SCT, SCB, SCTE. Pegasus local.
The Spaniard is offline   Reply With Quote
Old 03-26-2012, 05:46 AM   #34
kufman's Avatar
I wouldn't say that is true. As I said before, I have seen the exact same problem with Futaba receivers and HiTech servos. It all comes down to the quality of the BEC. If we were all running receiver packs, we never would have discovered the problem. With all the different equipment that exists there is bound to be combinations that don't work perfectly.
Brushes? We don't need no stinking brushes!!!
kufman is offline   Reply With Quote
Old 03-26-2012, 07:09 PM   #35
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
What esc do you have?
I'm running an RX8/Pro4 and Savox 1256 and my electronics will shut off.
I addded the glitch buster but problem is still there.
What external BEC did you use? How do you wire them in?
XRAY T4 17' //CRC Gen X SE- 17.5 GT//Xray X12-17' GT12//Xray X12-18' 17.5
check out the new 12th scale GT class!
https://www.facebook.com/groups/148391312353349/
JEFFs SC10 is offline   Reply With Quote
Old 03-26-2012, 07:50 PM   #36
The castle BECs work well, they have instructions included about how to wire them up.
Old 10-28-2012, 02:40 PM   #37
Send a message via MSN to rnelias Send a message via Skype™ to rnelias
Originally Posted by kufman View Post
Efficiency is the measure of mechanical power out divided by electrical power in. It has nothing to do with how the power is drawn. That would be more of a power quality or EMI issue.
It isn't just the Savox servos that cause this problem. I have seen most of the other companies servos do the same thing (HiTech, Spektrum, etc). They are really strong servos and depending on your ESC and receiver, you may have 0 problems with them. In my case, I had to use caps with my MMP ESC and Futaba receiver, but not with my Tekin RX8 ESC. The bec on the Tekin is stronger and has more output capacitance than the MMP. I can run weaker servos on just about any ESC without trouble (Futaba 3305).
Dave H, I like the Jrx-Pro you have in that picture. I have one that looks just like it, pink steering parts and all, lol!
Well, bad luck i have
Exactly the same problem here. Savox 1258 and Tekin RX8. I thoughtbthe problem was my receiver, changed it and the problem persisted. I'll try the cap solution before attaching it to a external bec...
rnelias is offline   Reply With Quote
Old 10-28-2012, 02:57 PM   #38
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Originally Posted by AZBOB View Post
I'd say get a BEC and forget about it. (set it and forget it)
I thought that too until this past Sat. when my BEC went bad..........talk about a be-och trying to find the problem! It was the last thing I checked after about 2 hours of fiddling with things. The motor started cogging and would not rev up, I first replaced the motor then the speedo well there was only 1 thing left to try. It was a Castle 10 amp bec that was bad and it was only about 4 months old.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 10-28-2012, 07:37 PM   #39
kufman's Avatar
Sounds like your Castle BEC failed in a nice fashion. Mine put 16V into the receiver.
Old 10-28-2012, 07:51 PM   #40
Send a message via AIM to turbo4age
this is also my experience.
everything... nearly everything
turbo4age is offline   Reply With Quote
