Breaking an Engine in During the Winter >
Old 01-23-2005, 11:33 AM
Default Breaking an Engine in During the Winter
I just got an HPI MT2 and I really wanna start breaking it in. It's pretty cold outside, about 26 degrees. Is there anything wrong with breaking it in in these temperature. Thanks alot for your help.
Mike2002 is offline
Old 01-23-2005, 11:37 AM
Suspended
Location: please try not to look at my avatar to long may cause u know what
yes DO NOT BREAK IN UR MOTOR WHEN IT IS COLD. it wont break in righ and your piston and sleave will go a hole laot sonner
andy_666 is offline
Old 01-23-2005, 04:03 PM
OvalEvader's Avatar
Cover the head in aluminum foil, with a small hole for the ignitor. Then, heat the engine up to operating temp (200ish) with a hair dryer or heat gun. Run the break in with the body on, and when you are done with a tank of gas, bring the car inside to cool at room tempature. Its also best to heat it up at room tempature, and don't let it sit outside too long.
OvalEvader is offline
Old 01-23-2005, 05:07 PM
Suspended
u could do that also but just wate untill winter is over and dont take the risk
andy_666 is offline
Old 01-23-2005, 05:26 PM
How about when it is around 47 degrees outside. Is that also too cold for it because it shuold be warming up to around that in the next few days. Thanks
Mike2002 is offline
Old 01-23-2005, 06:28 PM
Suspended
im from canada so not to fimilare with degres but i would say any thing above 7-10 degrees celsous that is when i brok my motor in
andy_666 is offline
Old 01-23-2005, 11:02 PM
Aaron Waldron's Avatar
That's what the foil is for..it will keep the engine hot.
OvalEvader is pretty knowlegeable, and he gets his info from great sources. You guys really oughta start trusting him more often..
Aaron Waldron is offline
Old 01-24-2005, 05:44 PM
Sofast-NT's Avatar
I used the foil on my tr the foil works really good.
Sofast-NT is offline
Old 01-24-2005, 05:51 PM
Sofast-NT's Avatar
If i wouldnt have used a hair dryer i wouldnt have got it started.
Old 01-24-2005, 06:17 PM
I'm assuming that the foil goes around the cooling head(heatsink) and not the acutal head of the engine. Is that correct? Thanks
Mike2002 is offline
Old 01-24-2005, 06:28 PM
OvalEvader's Avatar
I try and get it to cover as much of the engine as possible without getting in risk of getting caught in any moving parts...if its REALLY that cold out, then you want to keep in all the heat you can.
Old 01-25-2005, 06:33 AM
ddesros2's Avatar
I do this in my house, here's what I do:
1. Take a plastic 500ml pop bottle and cut off the bottom of it.
2. Cut a peice of carboard the width of your window and 10 inches high with a hole in it the size of the bottom of the pop bottle.
3. Create a flexible "tube" with brown paper bag, tape one end to the cardboard in the window and the other to the pop bottle (I use duct tape)
4. Place the end of the pop bottle on the end of the cars exhaust and use electrical tape to seal it off.
5. Optional: Place a small computer fan (12V) at the opening of the carboard to vent the exhaust out, connect to power supply.
Prop the car up level with the window on your pit table and fire it up. All the exhaust will be vented outside and the oil residue will be captured by the plastic pop bottle. Don't do this when someone is sleeping, it will be loud!!!
By doing it this way you will be in the comfort of your home, at you pit table and the car will never be in the super cold air.
It's kinda crude but I've made this setup a couple times and it works like charm.
ddesros2 is offline
