Novak GTB with 13.5 motor on 2wd Slash >
Old 03-08-2012, 01:09 PM
tc5 man's Avatar
Default Novak GTB with 13.5 motor on 2wd Slash
Ok i have a question if i can use this motor on my 2wd slash ? Its the first generation of the brushless Novak motors . I just bought a 32 pinch jato spur gear conversion and i only have a 10t , 11t, 12t.
But i do have my 48 pitch spur gear and pinion as high as 21t .
tc5 man is offline
Old 03-08-2012, 04:52 PM
Trader Rating: 38 (100%+)
How many teeth are on your 32p spur gear? Is it like 54t? If so, even running the 12t pinion you will be a little undergeared, but it should work ok. Just run the 12t pinion and keep a close eye on temperatures on both the motor and speed control, check it every three minutes in the beginning and don't let temps get over 160F.
Matt
mattnin is offline
Old 03-08-2012, 06:55 PM
tc5 man's Avatar
Matt
Its a 58t Jano spur gear.
tc5 man is offline
Old 03-09-2012, 10:02 AM
tc5 man's Avatar
Anybody else know ?
tc5 man is offline
Old 03-09-2012, 10:07 AM
About 3 teeth on your spur is equivalent to 1 tooth on the pinion. The bigger the pinion the More top speed less torque, bigger the spur the more torque and less top speed. If that guy recommended a 12/54, than a 13/58 would be really close.
ptownhick is offline
Old 03-09-2012, 10:15 AM
tc5 man's Avatar
Ok got you i dont have a 13t pinion inless my Lhs does i do have a 48 pitch spur gear and pinion so i think a 18t or a 19t or 20t whould work good . I race on a tight indoor offroad track with a meduim size straightaway.
I know that usually brushless motors are geared higher than brush motors usually.
tc5 man is offline
Old 03-09-2012, 10:24 AM
I got the ballistic 13.5, motor timing at 38-40 degrees, I'm running 21/86 I think. I will check when I get home. I race on a 13sec indoor, clay track. Start off with a 19/90 if you can.maybe a 20. But check your temps for sure.
Old 03-09-2012, 10:28 AM
tc5 man's Avatar
Ok well i have a 86t spur and do have a 21t but i think a 20t whould work the best on a tight indoor track though.
The track im bashing/racing at will have carpet also.
tc5 man is offline
Old 03-09-2012, 10:41 AM
dug44's Avatar
Trader Rating: 29 (100%+)
With that 20t pinion and the 86t spur, you would be under geared about 4 teeth on the pinion. Might even be able to jump up to a 26t pinion....
dug44 is offline
Old 03-09-2012, 10:44 AM
tc5 man's Avatar
Dam lol thats a big pinion i dont even gear my E-truggy nearly that high but that is diffrent though. Ok il try a 21t and see if my Lhs has some 32 pitch pinions and some higher tooth 48 pitch pinions.
tc5 man is offline
Old 03-09-2012, 11:07 AM
dug44's Avatar
hahahaha.... I am running 36t pinion with 91t spur in my tc, that's a 17.5 though....
If you have an i-phone, or any smart phone for that matter, get the novagear app.... It's pretty good.
This works too...http://www.rcgearhead.com/Gearing/Browse
dug44 is offline
