Old 02-11-2005, 03:41 PM   #31
Oasis's Avatar
Trader Rating: 36 (100%+)
Yes,A few other differences also,dual brakes on the front,3 shoe clutch,hardend shocks/with 3.5 mm shafts(a problem..it uses 3mm ends )i know i'm forgetting a few things.
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 02-12-2005, 07:59 AM   #32
ericmyson's Avatar
How is the overall build of the kit. Is there ample lock tite where needed. Did any thing wiggle loose. I'm still waiting for my kit to come in, I was told this monday. Is there anything I should look into.
thank you.
p.s. with the stock motor and tank, how much of a run time can you get off one tank. thanks again.
ericmyson is offline   Reply With Quote
Old 02-12-2005, 08:25 AM   #33
Oasis's Avatar
So far everything has held together,have not re locktighted(?)anything,the best built RTR i have owned..not like i have owned alot(2.. )i would doubble up on the steering link though.
Old 02-12-2005, 01:01 PM   #34
ericmyson's Avatar
thanks
hows about the run time with the stock tank and motor is it good.
(approximate how many minutes?)
thanks again.
Old 02-14-2005, 11:14 PM   #35
ericmyson's Avatar
does anybody know if crazy nut racing makes a cooling head for the stock motor.
thanks
Old 02-18-2005, 03:04 AM   #36
ericmyson's Avatar
Originally posted by Chim-Chim
I had one of those trucks when they first came out. I bought the pro version with the
aluminum arms. I don't know which version you have, but the first batch of axels broke
at the drive pin. They were overhardened from the factory. Called HB, no problem they
sent the new axels right away. You can use the shiny axels off a Losi LST, just the bone
portion, and use your existing axel. Stronger than stock. Also you may want to double
up on the drag links, they bend pretty easily. The diffs are filled with very light weight
oil, like 40w shock oil or something. Try 5-7-3 in the diffs. I also increased shock oil
to 50w all around. Keep than long chassis from bottoming out on the takeoff of a jump.
Junked the stock HB motor for a Sirio 27xl pro version. Non-pull. Fast as hell. First time out
at the track qualified 2nd for the a-main, out of 3 monster truck outlaw classes. After a twenty
minute main I took the win with a lap and a half over second place, three laps over the rest of the
field. Awesome truck, just too radical of a design for some people. I loved it. I sold it to my
friend, and he just can't drive it enough. If you need help with that truck let me know, my friend
and I have alot of stick time and tuning with that truck, to make it handle much better than stock.
chim,
whats the difference in the handling characteristics if you move the rear hub carrier pin in the upper hole or the lower hole.
Old 02-18-2005, 09:25 AM   #37
sweet an rbtm928 in it its silly fast
mgtman is offline   Reply With Quote
Old 02-18-2005, 09:27 AM   #38
or this got both
Old 02-18-2005, 03:38 PM   #39
ericmyson's Avatar
if you double up on your steering link, does it affect bumpsteer?
I noticed there was bumpsteer with the stock set-up, I got rid of it though. I shimmed the steering knuckle, under the steering tie rod.
Old 02-18-2005, 04:25 PM   #40
Oasis's Avatar
No it wont affect bumpsteer because of the way the ball ends attach on the bottom of the link,all your doing is putting the "other" link on top not changing where the rod ends attach.
Old 03-05-2005, 01:50 PM   #41
Default Panther Pythons
I am new to Monster Truck racing. I've been racing 1/10 Nitor Trucks for about 8 years.
I have raced my Hot Bodies Truck a few times on reg sized Bowties with Trinity 3-piece foam.
The tires just has too much sidewall flex for my liking.
I was thinking of mounting one of the following:
Reg sized Bowties cut to fit Revo rims
40 series Bowties
Panther Pythons
I have heard that the 40s are very forgiving if you land a bit sideways of a jump.
Anyone have any good luck with the new panther pythons? How many teeth should I gear up with these tires?
toddzhere2 is offline   Reply With Quote
Old 03-05-2005, 02:35 PM   #42
Has anyone had luck with the new Komodo dragons?
They look like they are too low profile.
Old 03-05-2005, 03:45 PM   #43
Oasis's Avatar
I have a set but I dont really run them much,to many guys bitching about them..small size.I might be selling mine.. Opening a carpet track and wont be racing off road for a long time.. The selling would be the LSP
Old 01-26-2006, 10:35 PM   #44
Hi guys
I have a lightning pro the one with aluminum arms any way I'm having a lil problem with the stock engine.
Lately I have been using mugen seike gas 30% I switched back to my old gas which is 20% trinity not my engine don't even stay in iddle it dies out should I go back to 30%mugen gas?
Thanks guys
Any advice would be greatly appreciated
Oh I'm impressed with this truggy I raced my friends trucks drag racing I beat them all. They have tmaxx tnx mgt all of them have two speed but my truggy run away from this 3 truck's
Thanks again guys
HARDRIVE is offline   Reply With Quote
Old 12-18-2006, 11:23 AM   #45
Trader Rating: 37 (100%+)
Anyone still bash/race the Lightning Stadium Pro or Pro "R"?
Nexus is offline   Reply With Quote
hot bodies lighning jrick78 R/C Items: For Sale/Trade 14 09-02-2008 08:22 AM
Hot Bodies Lightning Stadium Pro w/ RB S5 i_like_f150s R/C Items: For Sale/Trade 1 04-12-2007 04:03 AM
HOT BODIES LIGHTNING STADIUM kwilke R/C Items: For Sale/Trade 3 01-25-2006 11:54 AM
Hot Bodies Stadium Pro Truggy ca-tn R/C Items: For Sale/Trade 10 10-28-2005 09:08 AM
Hot Bodies Stadium Pro kford_11 Electric Off-Road 2 06-19-2005 10:56 AM
