Old 01-20-2005, 08:07 PM   #16
Charles_Howarth's Avatar
My experience is with R/C boat engines, so perhaps there is a disconnect here. However, every racer I have ever spoken with or asked advice from has used some sort of after run oil.
I am using the term after run oil generically. I usually use some mix of Marvel Mystery Oil and Prather After Run Oil.
Charley
Charles_Howarth is offline   Reply With Quote
Old 01-20-2005, 09:00 PM   #17
GregH's Avatar
Send a message via AIM to GregH
PB Blaster is much better then WD-40 IMHO... read the label...
GregH is offline   Reply With Quote
Old 01-22-2005, 02:03 AM   #18
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Do NOT use WD-40 on the inside of your engine! After Run will absorb the water in the engine, not just displace it.
Cheers
Drift_Buggy is offline   Reply With Quote
Old 01-22-2005, 12:40 PM   #19
Aaron Waldron's Avatar
Charles - Oil can get gummy and make the engine hard to start, and most after-run oils will ruin the o-rings in a carburetor. Some fuels simply recommend not using an after-run oil.
Traxxas knows what they're talking about and if they recommend WD-40, I'd use that until your warranty is up. I personally use the oil used in Trinity's fuel for after-run..hehe.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 01-22-2005, 04:23 PM   #20
GregH's Avatar
http://www.blasterchemical.com/store...m?Product_ID=1
Old 01-22-2005, 04:52 PM   #21
dam lol what to do, i never used 10w40, my friends use it, i use after run oil hobbico ,shoot on the bottle it said enhances performance, inhibits rust,and protects your engine and makes it last longer now is that false advertising or no so many opinions geesh
mgtman is offline   Reply With Quote
Old 01-22-2005, 05:23 PM   #22
JoshR 85's Avatar
HeY hEy!!!
I heard that it also may screw it up, and i've used it and still nothing has ever happened yet.the only time i use it is when i'm done using it for the summer/ fall like about november when it's time for winter.
JoshR 85 is offline   Reply With Quote
Old 01-22-2005, 05:34 PM   #23
really i use my every time i store the car for more than a couple of days and make sure i drain all the gas i can before i put it in
Old 01-22-2005, 05:37 PM   #24
cause even if you have a drop of gas in it it will gell up a little do a test if you dont belive me put a drop in some plastic container and check it after a couple of days it does gell up a little
Old 01-22-2005, 06:03 PM   #25
Trader Rating: 28 (100%+)
I like wd-40 to clean the chassis and make shiny. But not in my motor. Marvel mystery oil does great there. And for nuts bolts, bearings, whatever. Like the post above says, take an old sleeve or something, put it in a container and liberally spray it with wd-40 and let it sit. Gels up and you have to clean everything again. I had my motor apart and all cleaned one day. Put it in a zip lock doused with wd-40. Next day when I want to assemle, the stuff is nasty.
Also don't let parts sit in isopropl alcohol for to long. They rust up real fast.
jbrow1 is offline   Reply With Quote
Old 01-24-2005, 01:07 AM   #26
vti-chris's Avatar
What else can we use.Some say automatic fluid that we use on auto gearboxes.
vti-chris is offline   Reply With Quote
Old 01-24-2005, 07:13 AM   #27
GregH's Avatar
I tell ya, you should try the PB Blaster stuff. It WILL NOT GUM UP if left sit for a LONG period of time. It works great as after run oil.
Old 01-24-2005, 07:47 AM   #28
Marvel Mystery Oil and tranny fluid like you say both work well.
Old 01-24-2005, 10:57 AM   #29
ok im definetly going to try the pb thanks dude
Old 01-24-2005, 11:39 AM   #30
GregH's Avatar
I've been using it for a few years now. I can store my engines for months and they still are freed up and not all sticky feeling when I check them.
It also helps restore rubber seals and o-rings and DOES NOT evaporate, it's a great moisture displacement as well. Another thing is, it has a additive that bonds to the metal and allows it to help seal worn engines.
I use it to beak-in my engines as well. What I do is spray a shot or two in the tank before I fuel it up then start my beak-in proccess. Doesn't hurt a thing and helps the engine to last longer.
GO 28R/Full Starter Engine GRracing Ver.Team Fully Modified Engine handpiece Onroad Nitro Engine Zone 0 07-28-2007 03:42 AM
Ofna Picco .21B 3 Port engine, good budget engine Cain Electric Off-Road 1 03-26-2007 08:32 AM
selling custom savage roller with engine, truck zillia modded engine.$275 pat360xboxhalo3 R/C Items: For Sale/Trade 2 01-11-2007 05:23 AM
mugen mst1 with engine and pipe f/t for 1/8 buggy engine tony montana R/C Items: For Sale/Trade 5 08-22-2006 04:52 PM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 11:49 PM
