Losi SCTE + Orion R10 Pro + Tekin Pro4 4600 ??? >
Old 02-23-2012, 11:13 AM
Toiffel's Avatar
Trader Rating: 52 (100%+)
Default Losi SCTE + Orion R10 Pro + Tekin Pro4 4600 ???
Anyone run this set up or know if the esc will be able to handle the truck and that specific motor ???
Toiffel is offline
Old 02-23-2012, 11:16 AM
e_lu_sive1's Avatar
double check the rating on your esc..60A-180A idk there a lot of esc out there..when u find that..u should know..hope that helps.
e_lu_sive1 is offline
Old 02-23-2012, 11:19 AM
Toiffel's Avatar
Looking at the 160A 2s model ....
Toiffel is offline
Old 02-23-2012, 11:25 AM
ovalracer1m's Avatar
Trader Rating: 29 (100%+)
should be ok. The orion has Hobbywing internals and the hobbywing 120A can handle that motor all day long. So i would think it would be plenty fine.
http://www.amainhobbies.com/product_...ess-Combo-105T
states it can handle 2-3s/ 2 and 4 pole motors.
ovalracer1m is offline
Old 02-23-2012, 11:28 AM
Toiffel's Avatar
This is the speedo http://tinyurl.com/7zlctmf , how about the weight of the SCTE, I remember some had problems handling the weight of the vehicle....
Toiffel is offline
Old 02-23-2012, 12:10 PM
seth556's Avatar
Trader Rating: 43 (100%+)
You should be fine, just put the fan on it. And it will be silky smooth
seth556 is offline
Old 02-23-2012, 12:31 PM
MrGidi123's Avatar
I wouldn't do that setup either go all with Tekin so put the RX8 in it, or do the R10 Pro +Vortex VST SC 550 PRO 4.5
Gideon
MrGidi123 is offline
Old 02-23-2012, 12:36 PM
Toiffel's Avatar
Why ? My RX8 is out for repair, and looking for a back up speedo, RX8 as of now are very hard to find, back ordered everywhere...
Toiffel is offline
Old 02-23-2012, 12:59 PM
e_lu_sive1's Avatar
mamba max pro?? i think i saw them of $119..if its a back up..just get something that can handle it..
Old 02-23-2012, 01:04 PM
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
There are multiple people running the R10 Pro w/ the Tekin 4pole in SCTE's at my local track w/o issue. I personally use it in a SCTE with a 4.5 550 and it temps off hardly above room temp with the fan on it. Plus, once you experience it's smoothness, you won't want your RX8 back anyway.
MarkA is offline
Old 02-23-2012, 01:11 PM
MrGidi123's Avatar
Go on ebay, you can find them NEW for a good price too
Old 02-23-2012, 01:17 PM
just run it, it will be fine. Put the fan on it like stated above, gear it correctly and wheel the thing. Another cheaper alternative would be the hobbywing Xerun 150A or the SCT Pro Xerun esc. Little bit bigger esc but is bulletproff and smooth as ever.
Old 02-23-2012, 01:48 PM
I run mine with atenshock sc411 4600 kv and its been real good
rickybobbyxxx is offline
Old 02-23-2012, 01:52 PM
Qwkrn U's Avatar
Trader Rating: 133 (100%+)
running the R10pro with a tekin 4pole and no issues. But its in a Durango SC. It was smoother than the Rx8 I had in it previously.
Qwkrn U is offline
Old 03-02-2012, 10:19 AM
Just got this esc/motor combo for my scte, seems fine. What version firmware, stock or mod mode and any settings from people using this would be helpful.
droors is offline
