this is my setup input welcomed scte >
Old 02-22-2012, 10:17 PM
Default this is my setup input welcomed scte
So the past 3 days I have spent hours on the internet trying to get a good SC set up. And this is not my first (its my second) so i went with the losi scte ARR roller. And this is my list
ESC-tekin rx8
motor-teking pro4 4000kv
Airtronics-mt4
Servo-Hitec HS-7955tg.
Anny input is welcome .
O and this is my first 4wd truck is there a good set of instruction on how to change the diff fluid thanks
neal90 is offline
Old 02-23-2012, 05:05 AM
symmetricon's Avatar
Trader Rating: 27 (100%+)
It looks like you have researched well, although, i do believe most prefer the 4600kv motor. I do however have the 4000kvmotor and it works very well, so....
As far as the diffs are concerned, you just have to get down and dirty with it, tear it apart and see how it all fits together. Just make sure you have some good degreaser.
symmetricon is offline
Old 02-23-2012, 05:19 AM
RCMICK's Avatar
ESC-tekin rx8
Airtronics-mt4
Im going threw the same thing. I have a:
Losi SCTE 4WD
RX8
Tekin 4600kv
TLR tuning kit
Savox SC1258
Futaba 4PKS
I just learned a few new things from the fastest guys at the track. Fill shock, make sure you get all the air out of oil front (35oil) 5 piston gold spring rear (30oil) 4 piston silver springs and then pull the shaft all the way down and repeat 3 or 4 times till when you push to top and you get a flat surface of oil no air bubbles, then put blader on top and bearly keep your finger on it (oil most likly come out alittle and then with shaft in up position and slowly pull down on shaft and it should sucktion the blader down and make a nice seal for caps, tighten caps on and make sure the shafts come out about the same. If the bladder pops off during process put a few more drops of oil in shock and start over.
I put my rear shocks bottoms to the rear of truck need a smaller screw (4-40 X1) works good, I put a gold nut where the shock used to fit so the screw will never com out.
Hope this helps I liked it.
RCMICK is offline
Old 02-23-2012, 06:01 AM
rcgod's Avatar
Trader Rating: 33 (100%+)
I would go with the 4600
rcgod is offline
Old 02-23-2012, 06:03 AM
thanks for the input on the shocks but its the diiffs that i need help on. Just not sure how to really fill the or how much oil to put in
neal90 is offline
Old 02-23-2012, 06:08 AM
RCMICK's Avatar
My fault
Pull the case off and you will see the whole gear and the 4 screws take out and clean all the grease out, and fill to full. 5000 front 7000 center and 3000 rear. dont lose the mini washers!
RCMICK is offline
Old 02-23-2012, 06:11 AM
BmainStar's Avatar
I would go with posting in the Actual SCTE thread!
BmainStar is offline
Old 02-23-2012, 06:13 AM
RCMICK's Avatar
4600 is smother and the 4000 has more torque and little more twitchy. Love my 4600.
RCMICK is offline
Old 02-23-2012, 11:03 AM
e_lu_sive1's Avatar
Wink
ESC-tekin rx8
Airtronics-mt4
ESC=Tekin RX8
Motor=Novak 550 4.5T
Spektrum DX3C
Servo=Spektrum S6040 just a rebranded savox
Batts=Gen Ace 5000mAh 2s 50c lipo. want to upgrade to a 60c or higher.
how u liking that MT4?? i think thats my next radio..
IMO u good to go..practice practice practice.
e_lu_sive1 is offline
Old 02-23-2012, 12:26 PM
I should be getting it ups in the next free hours
neal90 is offline
Old 02-23-2012, 01:01 PM
e_lu_sive1's Avatar
hell yah..i think thats a better radio than my spectrum..the mt4 does frequency hopping..the spectrum i think does hand shakes instead..in turn..the MT4 is way faster..MT4 FTW!! i wish airtronics would sponsor me..lol
Old 02-23-2012, 02:28 PM
timannnn6's Avatar
Trader Rating: 140 (100%+)
+1
timannnn6 is offline
Old 02-23-2012, 05:30 PM
8ight-e's Avatar
Trader Rating: 58 (100%+)
I've been running this basic setup for over a year with tons of success.
8ight-e is offline
Old 02-23-2012, 05:39 PM
Grandturk's Avatar
If i had it to do all over again I'd buy all the part needed for the truck without actually buying the roller since you want to replace most of the tuff anyway ths will save ou some time nd effort. Build it like a kit since TLR won't put one out.
Grandturk is offline
Old 02-24-2012, 07:25 AM
RCMICK's Avatar
Originally Posted by e_lu_sive1 View Post
ESC=Tekin RX8
Spektrum DX3C
4pks all day. Never tried
t 4
RCMICK is offline
