Tamiya DB02 1/10 4WD Buggy Thread
#34
Seeing that Tamiya is releasing an improved DB01 and re-releasing the DF-03MS makes me wonder if they pulled the plug on the DB-02. I thought the DB-02 was supposed to be a "sport" version of the 502X. A year and some change later you'd expect to have seen a DB02 with a different body or maybe even a DB02 Pro.
Is there something wrong with the basic design of the car? Racecrafter has had impressive results with the car. Watching Youtube vids, owners seem very satisfied with their car.
Hell, if they're dong the re-release thing can I get a Vanquish (plastic fantastic Egress FTW!) or at least a Thundershot?
#35
not sure, I managed to qualify 8th in mod 4wd at the Hobby Haven shootout this past weekend with my DB02. Honestly its a good car but needs a bit of help to get it to work 100% Ive finally gotten mine to be a very competitive car and really enjoy it. but also I think id like the 01 better.
#38
http://www.rctech.net/forum/electric...get-racer.html
#39
build finished. body mounted. getting run in modified in a few weeks.
#40
Great looking car! You do anything else to it? Tamiya sure knows how to make cab-forward look good
#41
Have added the following items
Tamiya big bores, fr & rr universals, motor heat sink (under chassis), metal hinge pin suspension balls, Kyosho ball end foams, Xray Alu wing washers, 3 racing Alu servo horn, Have placed 5.5 speed passion motor but may change to 7.5 when esc installed, tamiya pink wheels, also found during the build 1 extra shim added to rear diff to make the mesh a little tighter as there was a bit of side to side movement and have added bearings in place off brass bushes for steering, and that's it for now. Plan to run in 4wd mod within the next 2 weeks and have a spare set of db01 high traction arms but want to run it as is to start with and then go from there.
#42
RIP DB02? I guess it was a failed experiment. Tower lists it as discontinued
#45
Does anyone know if there is a gear diff option available that will work in the Db02 or 502x ?
