-   Electric Off-Road (https://www.rctech.net/forum/electric-off-road-4/)
-   -   mip cvd 1/4 or 3/16 for rc10 gt (https://www.rctech.net/forum/electric-off-road/5988-mip-cvd-1-4-3-16-rc10-gt.html)
evo IV 06-23-2002 12:14 AM
wondering why are there 2 different cvd for the rc10. also does anyone know which cvd came with the ft rc10 gt
CRASH 06-23-2002 03:23 PM
CVDs on a gas track is not a good idea. As you will see most factory drivers just use steel universals.
Losi Chaser 06-25-2002 10:58 AM
evo IV; FTgt has the 3/16 axles and they work great in the gt. universals are about $3.00 bucks cheaper then the cvd's.
Action-RC.com 07-09-2002 07:31 AM
Right. That was in the past that they used universals over CVD's. There's a reason they are included in the kit when ae made their own universals. The new RTR, FT, and Team built trucks are all 3/16's. The old tub sport kits, and first run of RTR's had the 1/4" axle. They have done away with that size, because it was more wheels the shops had to stock. You can tell a 1/4" axle because it tapers where the pin is to a bigger shaft to go through the bushings, and the wheels also have that 45 degree taper to them.
If you run CVD's, best thing you can do is pick up some CVD boots or put a piece of shrink tubing over the ball on the bone so the pin can't come out. It will chew the arm real nice if it does.
Content © 2001-2011 RCTech.net
