Team Durango DESC210R
#3811
As for the guy with anti-squat questions. I run 3/3 every surface rear motor. The track I ran on last night was dry dusty type. Ill post a setup in a few. I see that your asking gear diff questions, are you running one in your truck that has the issue? I've gone back and fourth with a ball diff vs gear diff, and every time I favor the ball diff. Its faster on all track types. I haven't rebuilt my ball diff since I built my truck in February, for Motorama. I have put the BFast kit in on the initial build, & its still super smooth. If you need more setup help, try and post a complete setup so we can figure your truck out for you.
#3812
The front shock springs seem to be too short. If I lower the ride height to where I want it then the springs are disengaged from the cups at full droop. This is causing my car to get really bouncy down the straight.
Do I have the wrong springs on or is everyone else noticing this too?
#3813
#3814
I limit the front droop to take up the slack. Indoors I run a pretty low ride height with less droop so it works great there. Outdoors I've been running a higher ride height, preloading the spring more and allowing more droop without the spring being "free" as you're describing.
#3815
You can use longer springs- Losi has some BB springs for their trucks and maybe Kyosho as well. The issue you may run into is finding one that is firm enough. I've yet to try anything softer than the softest spring in the "Hard" series of springs. If you're using softer springs though it should be a pretty easy fix for you.
#3816
Same here with both the stock and mod trucks. have been playing with stuff and the lightest "yellow" was ok but went to the light brown and was a lot better for the trucks as of late. Actually quite surprised by this on our "not as high of traction as leisure hours" track, haha
#3817
So I got a desc2!0 rtr I'm putting on it diggy cf front and rear towers Rf/RR alum bocks savox 1258 novak havoc sc pro 8.5.t what gearing sshpuld I start with
#3818
#3819
What are the dimensions of the battery tray? I've bought one and want to ensure my batteries on hand will fit. For some reason my work computer will not open the PDF of the manual.
#3820
I just got one of these trucks and noticed the same thing.even at 31mm ridehight at the chassis at full droop I have at least a 7mm gap between the spring and cup.my question is are people measuring at the chassis or the lowest part of the arm.seems very possible to lose the spring cup with that much gap.
#3821
So what gearing for a 8.5t and does the desc210 use the dex210 springs
#3822
#3824
#3825
