Gearing help...
Old 02-06-2012, 05:31 PM
Flagler's Avatar
Default Gearing help...
Alright, so I'm back into racing after a few years off. I have an SC10 and a B4. Someone help me with gearing for this track:
+ YouTube Video
Want something that's going to keep me from overheating, but perform fairly well, too!
Thanks.
Flagler is offline
Old 02-06-2012, 07:17 PM
Arigato's Avatar
What motor and what gearing are you currently running? What are your motor esc temps after a 6-8 min run?
Arigato is offline
Old 02-06-2012, 07:36 PM
Flagler's Avatar
I'm running Castle CM36 4600kV motor and sidewinder sv2 combo in the buggy. I have not run it yet, I'm just seeing if anyone has a good starting point. In the SC10, I'm running the stock RTR set up.
Flagler is offline
Old 02-06-2012, 07:47 PM
RatsacK's Avatar
Trader Rating: 21 (100%+)
Stock brushed or brushless? I'd be running the stock gearing and see how that goes, you won't need all that much top end by the look of it so both should go well on the track IMO.
RatsacK is offline
Old 02-06-2012, 07:54 PM
http://rctruckstop.com/2012/01/02/ge...uck-correctly/
This may help.
NHRCRACER is offline
Old 02-07-2012, 09:30 AM
brsilva's Avatar
As a starting point I would agree with above, start stock and see. There was one site i read once but i can't find now. It stated thet you should set your gearing so that your motor is wide open or near maxed out by the time you reach the end of your fastest stretch. This way you are getting the most speed you can while potentially not bieing over geared for you short slow spots.
brsilva is offline
Old 02-07-2012, 09:34 AM
brsilva's Avatar
Not sure what your transmmission ratio is but I had that combo in a Rustler running 16/90 trans mission is about a 2.5/1, It had good speed and averaged temps of 120-135f. You buggy is much lighter so your temps should be lower.
brsilva is offline
Old 02-07-2012, 11:51 AM
Flagler's Avatar
Thanks for the help, guys. If anyone else has any good tidbits keep them coming?
Flagler is offline
