22t springs on a sc10
I heard that some factory drivers are using losi 22t springs on thier sc10. And using 22 springs on thier buggies.
Does anyone have the part #'s for what is needed to switch my sc10? I usually run around gold fronts and green rear associated springs.
Thanks in advance
Thanks in advance
I am using Grey rears right now and waiting for the Silver fronts to get here.
Collar Traxxas #3768
Cups TLR5095
You will need to shave .060 of the front shaft eyelet to allow for the larger springs
I did this and Yellow springs with no preload give me 28mm of ride height.
Silvers are smaller by about 1/4"
If you use the alum. collars some are using It gives more room for adjustment for ride height. I just don't want to spend 25 bucks on them and shave a little over the towers to make them work
Cups TLR5095
