SC10 Hex Conversion Question
#61
Thanks Guys for the info just getting sc10 factory team together with
Orion r10 pro ,17.5
Everyone is telling me 28/75 gearing
Orion r10 pro ,17.5
#62
Nice setup, how big is your track that your running on? How long is the straight and is it clay/carpet?
#63
I live so California so many tracks to run on 3 clay tracks small 70-50 up to big 140-70 all about 1 hour away also dirt outdoor tracks all over the place big tracks. Where you from?
#64
For those bigger tracks with the long straights, that gearing is good, you obviously need to check your temps to make sure your not going over 160. But for a smaller track, I would start off around 81-84 for your spur and 19 pinion.
My local track is a small indoor clay track, I run 81/21 and it has worked the best so far, the other day just having fun on an open track day, I put a 75/25 in and it wasnt too bad, it just wasnt cutting out to my setup before that. I run a tekin rs and tekin redline 17.5, tonight I will be at the track for racing and will be trying a murfdogg 17.5 and see how that goes.
#65
Kahuna, I dont want to be that guy that makes this thread into a different topic so if you have any more questions about setup and whatever, pm me, ide gladly help you out!
Continue on with sc10 HEX, Go aluminum!!
#66
#67
i recently put together a sc10 ft and before i even ran it put the avid rear hex on and proline protrack beadlocks on it. and within 30 minutes of driving blew out 2 sets of rear huib bearings. is that somthing to do with my setup and would the b44 hubs fix the problem or has anyone else had the problem.
#69
#70
yes....off set is very confusing. I have a SC10 with the AE plastic hex conversion (already ordered the AE alum one but take forever to ship)...now, I need to get a set of PREMOUNT tires...eying the Jconcept BARCODE...but I know for sure the set for the SC10 (from Jconcepts) are the bearing and pins version.
If I need to buy Jconcepts premount barcode tires, using on the AE style hex, which one I should get..? I was told...on the front I need to buy the SLASH version and on the rear I will buy the BLITZ version....please help.
#71
#73
The SC10 4x4 12mm hex wheels make it the proper width. You can use the kit wheels, or most racers go with the +3mm wide track wheels from AVID, JC, or PL.
