Most complicated kit build? >
Old 02-03-2012, 08:12 PM
Default Most complicated kit build?
I'm looking for a challenge, I've built a few kits but they were almost mind numbingly easy... I love to tinker, I actually like building and fiddling with my cars more so than driving them. My only preference is that it's an electric kit, I don't care if it's on road or off road or anything just as long as it's electric.
kutless is offline
Old 02-03-2012, 08:30 PM
Davidka's Avatar
Trader Rating: 85 (100%+)
Find an old Schumacher Cat or Tamiya Clod Buster.
Davidka is offline
Old 02-03-2012, 08:42 PM
elex300's Avatar
Trader Rating: 106 (100%+)
Build a helicoppter that should be a challenge.
elex300 is offline
Old 02-04-2012, 09:43 AM
Buy a kit take apart any preassembled parts put them in a rubbermaid bin shake it up and put the whole car together with no manuel.
Woodbutcher is offline
Old 02-04-2012, 09:51 AM
My first ever RC was the most complicated I've ever put together. Tamiya Clod Buster
Hinecken is offline
Old 02-04-2012, 11:30 AM
ScottKelly911's Avatar
By a never assembled Kyosho Optima or Turbo Optima. Those things took forever to build
ScottKelly911 is offline
Old 02-04-2012, 11:37 AM
Planespotter's Avatar
Buy a car from the 80s and restore it. The kits these days are much better engineered and go together very easily. I recently put together a vintage Cox/Kyosho Gallop and was blown away at the amount of shimming, fitting and even fabrication it took to make it work right.
Planespotter is offline
Old 02-04-2012, 11:46 AM
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
you can always take an existing kit and "frankenstein" it into what ever you want if you have the skillz to do so.Heres a couple pics of a losi XXX CR I turned into a full cage sprint.complete redesign including molds for vacforming the hood and tank sections.It was a very fun project.
Attached Thumbnails Most complicated kit build?-100_2535.jpg   Most complicated kit build?-100_2540.jpg
2wdMod is offline
Old 02-04-2012, 11:56 AM
Anything "scale" can provide the challenge you're looking for. Building a scale RC is not for the feint of heart.
Hinecken is offline
Old 02-04-2012, 01:16 PM
FNG RIDER's Avatar
the Tamiyas all go together perfectly, if you follow the directions. The best kits available.
the American made kits have been another story. I assembled a Associated TC3 when the first came out and it took over 8 hours including painting and trimming. body and tires were not included! All the plastic and fiber reinforce parts had flash and tolerances were marginal. A lot of sanding, filing and reaming was required to get them to fit perfectly. I don't think the newer Kits from Associated nor Losi are much better. Someone can correct me if I am wrong! Heh! Or even try a pan car,
I think all of the pro build on-road kits would be a challenge to build even if the parts fit perfecty, such as with the Tamiya. you have to assemble each shock, differential, cvd, arms, chassis and paint and cut out the body.
They are expensive, complex but very fine racing cars.
I like the assembly too, and really enjoyed the build, unless I had a big race the next day.
let us know what you decide and post up a buld thread.
Have fun!
wn
FNG RIDER is offline
Old 02-04-2012, 01:30 PM
Build? How about changing a spur gear on a Losi XX-4 between rounds?
OnlyVees is offline
Old 02-04-2012, 01:33 PM
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Tamiya semi truck..
racer1812 is offline
Old 02-04-2012, 01:44 PM
There are no hard to build kits, only poorly written instruction books.
Sleepytime is offline
Old 02-04-2012, 02:11 PM
R/C Tech Elite Member
abailey21's Avatar
Trader Rating: 36 (100%+)
Tamiya Semi with trailer was the hardest for me.
Do it without instructions for a real challenge
abailey21 is offline
Old 02-04-2012, 02:35 PM
I just looked at the manual for the Tamiya Scania R470, then the flatbed trailer. I actually closed the window in disgust. Holy shit, props to anybody that could get those together.
WindDrake is offline
