!!! WOW How big is your foam !!!
The tire foams provided in the kit with the holeshot tires are huge compared to the tire. Is this typical for all foams in this scale ? Who trims the foams to a closer match to the width of the tire ? Who shapes the foam to conform to the bead or shape of the tire.
Some trimming and shaping advice please !!!
Stuff them. The kit tires are proline holeshots, in my opinion, proline has the worst foams out there and if you cut them down, they will break down and go almost flat before you even wear out the tire... So stuff them full. I trim all 4 corners of the foam just a hair and shove them in.
stuff it in there and feel it, try another foam and another and another until you get one you like then trim as desired for final tuning and fit. Open cell foams in general are bigger and softer so they need to be stuffed, closed cell foams in general can be made to better fit the shape and don't deform as much. Every track and person has different needs so mix and match as you like. I like tea with my crackers, some like coffee.
Super Moderator
Trader Rating: 31 (100%+)
Cheers guys will take it all on board.
