Anybody get the Avid motor centering kit for the associated b4.1
I got mine yesterday. i didn't use the stock spacer that goes on the top shaft. the tranny case won't close if you use that spacer. as far as the blue spacer, just slip that onto the top shaft after the case is closed and before you put the slipper disks on.
Just a thought.
NOT talking bad about the product, looks like a quality product.
No instructions!!!!!!!!
Avid or any company who doesn't include some kind of instruction, if there is some assembly required. Is just wrong!!!
Just installed the JConcepts carbon steering rack on my SC10, they included a simple 4" x 6" picture with text instruction sheet.
Seems to me that JConcepts wants to keep me spending $$$$$ with them. And in this case Avid doesn't need my $$$$$
From Avid's Facebook page
Kurt Wenger - Just take apart the gearbox, pull the kit topshaft and spacer out. Put in the new topshaft and the blue tube goes on the outside now. Then add the motor plate spacer and motor plate with the longer screws to hold it on. Make sure and keep the washers under the screw head.
Seems the AE topshaft spacer isn't needed, cause Kurt didn't say to put the spacer on the Avid topshaft.
