How to make my RC8TCE Electric tekno v4 conversion lighter ?
Ok im wondering how to make my truggy lighter with easy things to do i already have the two titanuim or alum associated rear camber links but the front turnbuckles for the camber are steel and so is the steering rods. Whould buying the rest of the lighter buckles and a alum screw kit make it lose some weight little by little ?
Anybody know ?
Well i do run soft cased lipos i know that keeps the weight down but the thick long front driveshaft the tekno kit comes with added weight i believe maybe not though. Im coming from running the associated Rc8t conversion kit but this kit i have now is much better balanced.
I do have a pair of proline calibers that are light so il see when i mount them on.
I was looking at the carbon towers for the Rc8t i know that whould make a big diffrence but they lack the extra tuning holes. I know heavyer does make it better but theres a limit though lol.
Im running a 2200kv motor with 4s lipos.
so if you replace every think with carbon towers and rest like the mugen does then it be light as a mugen am i right
There is not much meaningful weight savings you can achieve in the chassis. Concentrate on wheels and tires, there is a lot of weight variance there and that makes the most noticeable difference.
Zebon: Yea i could do that and it would make the truck less a little bit of weight but like i was talking about on here it doesnt have the extra tuning holes that the CE towers have even though ive only ran the stock setting holes.
David: Makes sense although im still going to get rest of the titanuim turnbuckles mind as well since i already run two of them.
Ok il try that i wonder if they can make the same about of holes on the shock towers as the RC8TCE alum towers ?
Does a graphite steering link remove weight really compared to the alum ones to me it seems like mimunuim loss ?
Makes sense i looked at the website you gave me the only ones from assoicated that they make is for the SC8 with 4 holes for the roll center but if i call and ask maybe they can make ones for the RC8T with 7 holes like the (CE towers)
Wait. Didnt you post numurios times that a heavy truggy drives better then a light weight one. That a heavier truggy is more planted, That the added weight isn't noticeable on the track? What happened to theae theories or was it all smoke?
Well yes it does but the RC8TCE as electric is heavyer than running it as nitro when i had my Assoicated conversion kit it was to heavy but now with the Tekno v4 chassis . It comes with a long front driveshaft thats needed to run but after i mount everything and than the tires it might be the same weight its likely just me being paranoid lol. So yea heavyer weight does drive better but theres a limit to it.
But buying lighter stuff doesnt hurt it that much if its not a major weight loss.
Good awnser.
