Duratrax DXR8-E
#1637
On all three diffs, before I opened them up, I could easily feel more free play, much more free play, on one outdrive compared to the other. One side a mininal, tiny amoubt of slop, like a properly (IMO) shimmed outdrive, the other side much more/too much. It looks and feels like about exactly the amount of play that another washer, part #20 in the Sat/Sun gears set, would take care of.
The manual includes this part on both sides. Also, it would be nice if different thicknesses were available from Duratrax.
Also, it seems to me that as standard practice, it is a good idea to shield the orange rubber seal from the rotating pin. And when there is thicker oil in the diff and/or large rotating stresses on the gears, which would tend to push them apart, that drive pin could wear on the seal and even the housing. A steel shim would protect everything.
Also, if your outdrives were a little worn or notched, the dog bone drive pins will settle into those notches and pull hard outwards on the outdrives at full suspension travel, definately pulling those drive pins against the housing. Maybe causing tiny metal filings and therefore wearing everything out.
Anyways, mine are too sloppy regardless.
#1638
I could'nt find any shims good enough for my tastes at the hobby shop, although the Ofna clutch bell shim kit at $5 had some shims that would fit, but they were a little small in outside diameter. I ended up buying a 3/4" wide by 1 foot long strip of thin (.4mm) stainless steel. I can fashion a workable shim out of that. I only need 1. It might be a little thick, but I will fit it up and see. I can sand it down a bit. Whichever outdrive has the most slop will get the first test fitting. It might be just right.
#1640
I'm about to install my rear long shocks and machined shock tower.
So which way does it go. Does flat end face the front, having concaved holes facing the rear?
#1642
#1643
Thank you. One more thing. I can't seem to thread the shock end to the shaft. I don't have a thread tool or what have you. Any tips?
#1644
Just to give you an idea what the difference is between the stock and optional rear long shock.
This thing is looooooooong..... Can't wait to take this to the track.
#1645
Not sure how long this sale lasts, but I run these on my DXR8-E quite a bit with really good results.
Equalizers for $11.88
http://www3.towerhobbies.com/cgi-bin...&I=LR1754&P=DS
J
J
#1646
J
J
#1648
#1650
I have
I actually like the C2 better for testing or just having fun due to longer life. The C3's offer up more grip but don't last as long.
It just depends on what you plan on using them for.
I also use the Posse tires a lot too. They prefer a more "groomed" surface than the Equalizers do but offer excellent forward and side grip.
J
J
