-   Electric Off-Road (https://www.rctech.net/forum/electric-off-road-4/)
-   -   Help with gearing and timing on my SC10 please (https://www.rctech.net/forum/electric-off-road/586357-help-gearing-timing-my-sc10-please.html)
shelbyranger 01-11-2012 06:13 AM
I've tried searching the sc10 thread but can't find what i'm looking for. Can you please help? Currently I have a FT SC10 with tekin rs pro esc and a trinity D3 17.5. I run it at full can timing, full esc timing and boosted with 19/84 gearing. I like the punch it has but could use abit more however on the straight it seams im giving up some speed. I race a small indoor hard packed clay track. Its very tight with many jumps and only 1 50-60 ft straight. However there are several very tight turns that require great punch be competitive. I bought a RevTech 17.5 to try tonight at the races, any recommendations on timing and gearing? I wont have alot of tuning time tonight before the race
Ivegotklas 01-11-2012 06:18 AM
When ever I run my SC10 with the D3 or Revtech 17.5 I use 28/76 (D3) or 28/76. 19/84 would be good for a 8.5t motor. I use timing on both motors. Usually around 20-30 degrees on the ESC and have it turned up on the motor too.
nadan805 01-11-2012 06:20 AM
Maybe you should try lowering the can timing while using a bigger pinion. Also search in the SC10 gearing thread :
http://www.rctech.net/forum/electric...ng-thread.html
shelbyranger 01-11-2012 06:33 AM
I took a look at that thread ybut there isnt really any talk about running boosted 17.5's. I know running boosted I know you I can drop the pinion. I'm just confused if i'm running too small of pinion and hurting torque and speed?
Joliet Jake 01-11-2012 07:47 AM
Great information there. :tire:
rcbo 01-11-2012 06:54 PM
A good place to start 24/84 50 boost 10 turbo 0 timing on motor.
Make sure to check motor temps.
