TEN-SCBE RTR AVC 1-10 4WD SCB >
Like Tree12Likes
Old 05-28-2018, 06:41 PM
  #286
Wohoo! Almost done with this truck. Finished up with the soldering the ec5 on the speed control and then bind everything up
SLO county race is offline
Old 05-28-2018, 08:57 PM
  #287
Looking good mate and that's going to fly��
martin34 is offline
Old 05-30-2018, 09:54 PM
  #288
Ordered the king headz motor mount and centre diff mount this morning.Going to put fluid in the diffs when I fit these parts.I can't find much on the scbe but the popular choice for the scte is 5,5,3 or 5,7,3.
martin34 is offline
Old 06-01-2018, 11:05 AM
  #289
Motor fan turned up but looks a little small
martin34 is offline
Old 06-02-2018, 02:45 PM
  #290
I couldnít find much either. I was running 5-5-5 but I decided to run 5-10-5 and I like it more. I felt like the 5k center diff fluid was a little to thin. Keep in mine this is a basher. I may raise the front to 7k but itís doing alright for now.
I just bought the HW C1 motor fan. Itll
be here at the end of the week hopefully so Iíll post pics up once it is mounted.
Old 06-02-2018, 11:44 PM
  #291
Looking forward to seeing the pictures mate.The fan I bought is just a cheap eBay one so I am not sure how good it will be.I won't do my diffs until the king headz parts turn up.I ordered from amain and I am in the UK but normally it only takes a week or so.
SLO county race likes this.
martin34 is offline
Old 06-10-2018, 05:33 AM
  #292
I bought this program card but it doesn't seem to work.Plug the ESC lead into but nothing happens😥
martin34 is offline
Old 06-10-2018, 06:08 AM
  #293
chainsaw10's Avatar
i have that program card for a few escs . You have to plug it in BEFORE you turn power on. Donít plug it in while power is on....it wonít work. And make sure the plug is in right, itís easy to plug in backwards.
chainsaw10 is offline
Old 06-10-2018, 07:11 AM
  #294
Thanks mate.What I did was plug it to the ESC lead and then connected the battery and nothing.Switched on the ESC(not sure if I am ment to)and still nothing.Did the same but with the ESC plug turned around and still nothing.switched on the ESC and got two red lines in the item side and one in the value side but that was all it would do?
martin34 is offline
Old 06-10-2018, 09:33 AM
  #295
chainsaw10's Avatar
Hmmm...not sure what’s wrong then. Is that the card that has two separate ports? You tried both, with plug in in every possible way?
Old 06-10-2018, 09:39 AM
  #296
Hmmm...not sure whatís wrong then. Is that the card that has two separate ports? You tried both, with plug in in every possible way?
Yes I have mate and just watched a YouTube video and done it the exact same way but all I get is the red dashes.
martin34 is offline
Old 06-10-2018, 01:36 PM
  #297
fyrstormer's Avatar
Does your ESC have a secondary port on it, like for connecting a fan or something? If so, you have to connect the program card to the secondary port instead of the main port.
fyrstormer is offline
Old 06-10-2018, 09:06 PM
  #298
Yes it does have a port that the fan is plugged into.I have ordered a lead and I will give that a go.Thanks.
martin34 is offline
Old 06-12-2018, 08:39 AM
  #299
Thanks for the info about the lead as it came today and the card works now.All the setting were the same as the manual apart from number 9 which is timing.In the losi manual it says setting number 1 which is 0.00 but mine was factory set at about number 6?
martin34 is offline
Old 06-12-2018, 08:46 PM
  #300
I emailed horizon and they have replied saying it should be 0.00 so mine was set wrong out of the box.
martin34 is offline
