looking for charger opinions >
Old 01-08-2012, 02:17 PM
Default looking for charger opinions
I am coming from motor and im learning alot as I go. My current charger is a Dynamite that will charge 9a and balance. I don't think this will meet my goals.I would like to have a charger that will charge 2 packs in 30min or less. I plan on having 6 packs. They will be all 5000mah 35c packs. Some 2s and some 3s so I can run the Flux on 4s, 5s, or 6s.
Any suggestions on what will fit the bill for my 30min charge times. Somthing reasonable in price. I would like to spend 200 or less. I have looked at the Progressiverc stuff. I think the I308? I think this might be overkill but I really don't know. Maybe something out there a little less in price that will meet my needs.
Thanks for the help
ffr3247r is offline
Old 01-08-2012, 05:21 PM
Curious about this as well, I am tired of my passport charger that takes 1 hour for one battery!
Usrname_Unknown is offline
Old 01-08-2012, 05:30 PM
jonee589's Avatar
I have an iMax B6 Ultimate. Its a great charger, real quick. I would recommend you checking one of them out.
jonee589 is offline
Old 01-08-2012, 05:39 PM
jsinclair's Avatar
Icharger 206b , its got the power. It stays cool and has a warranty.
jsinclair is offline
Old 01-08-2012, 06:17 PM
IROC-AR15's Avatar
Trader Rating: 29 (94%+)
+1 I have a Titan B6 same as the iMax B6. Comes with all charging adapters you'll ever need. I use it for both my nitro and brushless truggy. I think I got mine's for $20 shipped and then another $12 for a ac adapter.
Don't let the problem fool you. I have never had any problem with it and it doesn't even get warm even when I'm charging back to back to back.
Forgot to add that it has Clips so I can charge off my car battery if I want!
No fuss no hassle smooth operation. Charges my 5s in about 20-40 minutes depending on how much I drain it.
IROC-AR15 is offline
Old 01-08-2012, 08:52 PM
lodhammerdin's Avatar
Trader Rating: 77 (100%+)
I use a HITECX4. Can charge in around 30-40 minuts. Around $150.
http://www.amainhobbies.com/product_...rger-6S-6A-50W
Try this if you want DC power.
http://www.amainhobbies.com/product_...ger-6S-50W-x-4
lodhammerdin is offline
Old 01-09-2012, 12:54 AM
aSab's Avatar
the iCharger has great support, frequent updates to its software, nice and valuable features (I like the discharge+ the most). go for it, you won't regret it. don't be fooled by other brands where they add lots of cables with the charger - this ain't the feature you're looking for.
aSab is offline
Old 01-09-2012, 06:11 AM
IROC-AR15's Avatar
The Titan B6 has discharge also along with store, fast charge, and balance of lipo up to 6s. It has a lot of pigtails for different battery setups not to make up for its lack of features cause it has none can even charge a Pb battery. Don't be fooled by those $150+. My Titan B6 has never let me down, you can set the charge amp, temp cutoff, LVC, max MAH among other things all for a great price that won't hurt the pocket. You can go out and spend a $100+ on a charger but why would you when you don't need to? Higher price does not equal better
Old 01-09-2012, 06:46 AM
jurquhart's Avatar
Trader Rating: 22 (100%+)
+1 its great to be able to charge 4 lipos at once. They can all be different sizes as well
jurquhart is offline
Old 01-09-2012, 07:13 AM
I've got a Thunder T6, same thing as the Hitec X4, but a bunch cheaper ($90 vs. $150). Being able to charge 4 batteries at a time is great.
http://www.hobbypartz.com/75p-t6-multi-charger.html
WindDrake is offline
Old 01-09-2012, 07:16 AM
sircrashalot's Avatar
had the hitec x4. The issue is that you can only charge at 5 amps per channel with that charger.
sircrashalot is offline
Old 01-09-2012, 08:01 AM
Yeti AS3's Avatar
The X4 can charge at 6A in all 4 ports.
Yeti AS3 is offline
Old 01-09-2012, 08:13 AM
forty6's Avatar
Thanks for the help
You're on the right track. I have an i306B and very happy with it.
forty6 is offline
Old 01-09-2012, 08:22 AM
R/C Tech Elite Member
Trevor Williams's Avatar
Trader Rating: 207 (100%+)
Is this the IMax B6 everyone is talking about?
http://www.ebay.com/itm/Digital-LCD-...item4842d34e14
Trevor Williams is offline
Old 01-09-2012, 08:53 AM
IROC-AR15's Avatar
Yes that's it exactly or the Titan B6 which is the same thing that I have. Haven't failed me once even charging my 4s and 5s lipos back to back with each other. That price though is a lil more than what I paid. I think I paid $20 shipped for the charger then got an ac adapter from another auction for $12 shipped. Was kinda upset cause once the charger came I realized my laptop cord worked with it perfectly. I've used every function on it that I stated earlier and no problems almost a year into to it. Never even got warm.
