Center Diff Help
Center Diff Help
Just finished building my RC8be...no this is not my first kit build but it is my first 1/8 build. For some reason the front diff rotates perfectly fine when spinning one tire and the other tire rotates the other way.
However when I apply throttle or manually try to rotate both tires in the same direction I get a hard bind to a point where they lock immediately.
Did I insert some spider gears incorrectly??
Last edited by alexchen86; 01-01-2012 at 12:13 AM. Reason: Problem Identified...Need Input Though!
