car does donutes HELP!
#32
The rustler is MY car had it for a few years. it was my friends car i loved it when he had it. got it from him for cheap and been upgrading it. the castle electronics I got I bought for it. wanted something a bit faster so pulled them out and stuck the novak gtb 5.5T 540 combo in it. I am just fixing up the duratrax to sell to help finance my 4wd truck build.
Im running the gens ace 5000mah 40c hard case lipo's love them.
#33
Well guys Figured out that problem 2. damn idler gear...When I had it apart before I did not notice it because it appeared fine
But when I pulled it out a few minutes ago and expected it, I found the problem
#34
That wont cause it to do donuts. It just wont let power get from the motor to the wheels.
#35
I've had the same problem with the same truck in the past couple of weeks.
First thing I found is that a 6000kv + motor is waaaaay to powerful for the truck.
The second thing I found was that the ball diff was destroyed - the holes where the balls go were non existent - just four really big holes , the other gears were fine (in my case). The thrust bearing had also collapsed.
I bought a new diff gear and a ball diff rebuild kit and the truck is now running better than it ever has! I am now using a 19t brushed modified motor with a 2S Lipo and still lifts the front wheels off the ground.
My advise would be, rebuild the diff and dial back on the power
Good luck!
Good luck!
#36
But after that I started getting a grinding slipping effect. thought something was up with my diff. so took it apart and found my idler gear was like that.
#37
Good luck!
Good luck!
Yeah I figured the motor be a bit much for that truck. I might get a better diff for the truck more heavy duty I bought a steel idler gear so I know that wont strip out again. We will just have to wait and see what happends.
#38
I tried finding a gear diff setup, but unfortunately I had no luck - if you wanted to go crazy power, that is what I would recommend
I have found that the evader is a great truck and stands up to some major punishment. I have had mine for nearly 10 years and the diff is the only thing that has really let go on it - and that was really my fault for putting a 5.5t in it for laughs.
Good luck and have fun!
#39
Try reading more before you post. I switched back tires and the donuts stopped. I found out it was something wrong with the back tires I was using.
#40
#41
