TeamNovak Havoc Pro SC with X-Drive
#436
Suspended
#437
FYI Jack - the Activ8 has different timing Setup than the Havoc Pro. The Havoc Pro starts at 20 degrees and go up from there. The Active8 tops out at 25 degrees and starts out at 5 I think. I assume this is tuned for 1/8 scale motors. Anyway - just FYI if you run higher than 20 degrees of timing. I think my recollection from the manual is right. It's not posted on Novaks site yet.
Edit - found the manual - the activ8 timing levels are - 10 13 16 18 20 25 30. The Havoc Pro is 20 25 30 32 35 37 42
#438
The first SC Pros I had were non-Xdrive. The Xdrive made them much smoother. IMHO.
#439
Just had my Novak SC esc go up in smoke instantly when I connected the battery. Wasn't even turned on.
Won't be getting a novak again.
#440
i dont see how people make there esc go up in smokes. i got 2 novak im a total noob to elc. got one last year hooked it up per instruction love it a lot run with hicups. got a second this year so far same thing. i am not saying it your fault or anything i just dont see how it goes smokes maybe i took extra carefully doing the work i double check then double check my work. I would contact them i hear the have great cutsmer service. and ther esc seem to be so dang easy to change set up too just by counting the light that flash heck my 4 year old getting that part down at least the counts anyways. Best of luck to you
#441
I didn't do anything out of the ordinary. Connected battery and it was an instant BBQ.
#444
Have deans plug
#445
Does anybody know if the Novak upgrade brain board is still available?
http://teamnovak.com/news/article/66/3
#446
#447
Well there must be an explanation cause I had Novak ESC's for as long as I can remember from the rooster to the Havoc pro and never had issues. I had a castle ESC since everybody was raving about castle and castle claims its water resistant but I ran it thru a small rain puddle and it went up in smoke my Havoc pro didn't have any issues with any puddle situations.
#448
