rear differential locked up
I am messin with a duraxtrax evender or something like that. stuck a mamba max pro esc and a castle 6900KV motor. when you reach half throttle + it just stars doing donuts. I have not figured out the cause im wondering what would happen if i was to take about the rear differential and lock it up some how so both back tires spin the same speed all the time.....How bad would that mess with my steering control?
yeah I just still want to be able to steer.
Is that a ball or gear diff?
If its a ball diff, try tightening a little.
If its a gear diff, remove, clean well, and relube with a heavier grease.
If you hold up the rear end, with the tires off the ground and give it throttle slowly, will both wheels rev up at the same speed?
