PIT BOX MUST HAVE ITEMS
#31
#32
allen drivers
socket drivers
Integy shock shaft pliers
Integy Quick pit drivers
Integy Quick pit sockets
Spare tips, .050, 1/16th, 1.5mm
Cordless driver for quick pits
Racers Edge diff tool
Racers Edge ball cup tool
Racers Edge shock piston finger drills
Hudy Setup System
Tire Balancer w/clay
Sharpie for labeling tire/compound/insert combinations
Digital Calipers
3 tierod wrenchs - Asoociated, Lundsford, Losi
Losi Ride Height Gauge
Losi Camber Gauge
Losi Shock Tool
Associated stamped shock tools for their cars
Losi shock tools for their cars, diff tool, slipper tool
Dremel (corded) with sanding drum, cutoff wheel, and a carbide cutting bit
Hakko Soldering station
Solder
Flux paste
3rd hand clamps
heat shrink tubing assortment
small cable ties
CRC wire hold down clips
spare deans plugs
spare bullet connectors
simple Green
shock oils 25, 27.5, 30, 32.5, 35, 37.5, 40 weights
Ofna shock stand
Green slime
AE steath diff lube and grease
tire glue w/ rubber bands
glue Tips
thread lock - blue
Rags
Q-tips
motor Spray
tire traction compound
Tire cleaning tub
hobby Knife and spare blades
double sided servo tape
straight lexan scisssors
curved lexan scissors
THS body reamer
needle nose pliers
side cutters
Exacto straight edge ruler
tooth brush
small pick (dirt from screw heads)
Pinions
Paragon pinion caddy
Spare sensor board for motors
Spare sensor cable for motors
Spare fan for ESC
Spare Axle bearings
Spare fasteners, body clips, nuts, wheel pins, etc.
That should be about it....
socket drivers
Hudy Setup System
Digital Calipers
Losi Camber Gauge
Losi Shock Tool
Solder
Flux paste
3rd hand clamps
small cable ties
spare deans plugs
simple Green
Ofna shock stand
Green slime
glue Tips
thread lock - blue
Rags
Q-tips
motor Spray
Tire cleaning tub
THS body reamer
needle nose pliers
side cutters
tooth brush
Pinions
Spare fan for ESC
Spare Axle bearings
#35
servo tape
#38
What are you guys using for pit boxes that they don't fit much stuff? a shoe box?
In the old days, I used to keep the bottom drawer filled with NiMH batteries and brushed motors, the box was really heavy back then.
#40
also some of the short course truck are hard to fix cant fit the normal hex tool in there except for short l handle ones. they wont stop the race it really depends on who you are. some races have stopped for half a hour cause the owner blew up his motor.
also the fact that im not fastest at fixing stuff i break at rc also the fact that im pissed off that do-sent help me fix it faster
#41
#43
Regional Moderator
allen drivers
socket drivers
Hudy Setup System
Digital Calipers
Losi Camber Gauge
Losi Shock Tool
Solder
Flux paste
3rd hand clamps
small cable ties
spare deans plugs
simple Green
Ofna shock stand
Green slime
glue Tips
thread lock - blue
Rags
Q-tips
motor Spray
Tire cleaning tub
THS body reamer
needle nose pliers
side cutters
tooth brush
Pinions
Spare fan for ESC
Spare Axle bearings
socket drivers
Hudy Setup System
Digital Calipers
Losi Camber Gauge
Losi Shock Tool
Solder
Flux paste
3rd hand clamps
small cable ties
spare deans plugs
simple Green
Ofna shock stand
Green slime
glue Tips
thread lock - blue
Rags
Q-tips
motor Spray
Tire cleaning tub
THS body reamer
needle nose pliers
side cutters
tooth brush
Pinions
Spare fan for ESC
Spare Axle bearings
Just kidding, I too bring it all and usually end up loaning to others who forgot.
#44
