Old 12-05-2004, 01:31 PM   #1
Send a message via AIM to somcoupe
Default clucth or trans???
I replaced the clucth in an rc10gt ran it about4-5 times and now when I give it gas the bell and spur gear move but the car barely moves? Do you guys think the trans needs a rebuild??
somcoupe is offline   Reply With Quote
Old 12-05-2004, 07:03 PM   #2
Trader Rating: 28 (100%+)
Sounds like you toasted your diff, or idler gear. Either one is pretty inexpensive to fix. If it's the diff, might as well get new diff balls and rings too. Although, check to make sure your slipper is tight, and the clutch isn't stuck before doing anything.
jbrow1 is offline   Reply With Quote
Old 12-06-2004, 09:51 PM   #3
never lift's Avatar
Send a message via AIM to never lift
check your output shafts the grub screws maybe loose
never lift is offline   Reply With Quote
Old 12-07-2004, 06:41 AM   #4
Possible you stripped a rim also. Look at the back of the rims where the roll pin sits in them. If this strips it'll do what you describe.
Old 12-07-2004, 05:24 PM   #5
Sofast-NT's Avatar
Tranny is burnttttt..
Sofast-NT is offline   Reply With Quote
xxxt rtr trans vs mf2 trans CBRRIDER Electric Off-Road 9 09-06-2007 09:34 PM
looking for a rc10gt clucth spring gannbig R/C Items: For Sale/Trade 0 06-22-2006 11:30 PM
WTB 13 or 14 tooth Clucth bell flaming-mo R/C Items: Wanted to Buy 0 11-19-2004 02:20 PM
centax clucth (complete) kawahara light flywheel fs/ft lapped u R/C Items: For Sale/Trade 2 06-03-2004 08:41 AM
How to remove pinion gears from clucth bell? mav Singapore R/C Racers 5 09-09-2002 08:08 PM
