Help with m11x and sPektrum >
Old 10-30-2011, 09:21 AM
Suspended
Default Help with m11x and sPektrum
I just bought a m11x and wanted to know how to make it spektrum capatable since all my cars r with spektrum receivers and wanted to make it easy on myself.. What do I need to do? Thanks in advance.
jonebonekc is offline
Old 10-30-2011, 08:09 PM
That is a no go.
Airtronics M11X Major Features:
* 4 Channel Computer Radio With Advanced Programming for Competition Cars, Trucks, and Boats
* Compatible with Airtronics 2.4GHz FHSS-2 Surface Receivers
* System Includes 6-cell 1500mAh Ni-MH TX Battery And Charger
* Transmitter AND RECEIVER ARE Compatible With Lithium 2 Cell Batteries
* Ball Race Supported Steering Wheel and Trigger With Adjustable Spring Tensions
* High-Power FHSS-3 Technology Gives The Best Reception And Connectivity Giving Racers Added Assurance
* 2.4GHz FHSS-3 System Is Integrated Into The Radio System Eliminating The Need For Modules.
* Transmitter Can Be Adjusted For Left or Right Handed Drivers
* Adjustable Back Light Display and Vibration Settings
* Variable Rate Adjustment Can Be Used to Self-Calibrate or Compensate the Servo Movement to 100% When the Steering Wheel Has Been Limited to Move Less
* User and Model Names Can be Assigned
* Assignable Switches and Trims
* Vibration Setting for Timer Notifications in Noisy Environments
* Adjustable Dial Can be Set for Dig Functions, Remote Needle Valve Settings, or Reverse Functions
* 30 Model Memory
* Customizable Menu for Commonly Used Features Instead of Scrolling Through the Radio Menu
* Easy Navigation Menu
* Easily Activated and Inhibited Mixing Functions While Driving
* Failsafe Programming Available On All Channels for Electric and Nitro/Gas Use
* Multi-Function Timer/ Lap Counter
* Electronic Traction Control
* Anti-Lock Braking System
* Throttle Hold Setting for Reliable Pit Stops for Nitro/Gas Use
* Speed Sensitive Steering and Brake Adjustments
* Exponential Control Settings for Steering and Throttle
* Adjustable Rate Control Settings for Steering and Throttle
* Throttle and Brake Mixing for Large Gas Vehicles
In my opinion, the Airtronics 2.4 ghz system is better than Spektrum anyway.
Bike racer is offline
