Old 10-29-2011, 03:27 PM   #1
Questions?? New 5000mah 40c 2s lipo erevo fit issues...
My current 2s 5000mah 25c tunigys fit fine because the cables come out the side. Then I run the cables through the vents. Well my new gens ace lipos cables come out top of lipo not side. Anyone else using these in erevo?
pic of issue.
Ogzer707 is offline   Reply With Quote
Old 10-29-2011, 05:02 PM   #2
Nogas's Avatar
You can either trim the battery compartment and vent to allow the cables to run straight out the top or modify your banana plugs (cut a groove in the side of the solder cup) and solder the wires so they come out of the plug at a right angle.
Tekno RC
MBX6e V4 Tekno
MBX6Te V4 Tekno
Nogas is offline   Reply With Quote
Old 10-29-2011, 05:58 PM   #3
Thanks for the reply. Im leaning more towards a lil dremmeling than a lil soldering. Especially on a lipo. I have absolutely no experience soldering on an energized component.
Old 10-29-2011, 06:04 PM   #4
tc5 man's Avatar
Make sure you have a soldering iron that at least gets to 900 degress and is 40wats.
If your not comfortble doing it than ask your lhs or a non local hobby shop to do it and the mod also to trim your battery tray.
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 10-29-2011, 06:12 PM   #5
Nogas's Avatar
You dont need to solder the pack, just the plugs (while they are disconnected from the pack) but if your not comfortable with it, then dremelling will get you running.
Tekno RC
MBX6e V4 Tekno
MBX6Te V4 Tekno
Old 10-29-2011, 06:33 PM   #6
Ok forgive me for my noobness here. What plugs are you talking about soldering then? the bullet connectors? I was thinking you meant to solder my plug(deans or traxxas) with cutting the bullet off and soldering that to the lipo? creating the angle i needed. Now im just confused when you said not to solder the lipo but just the plugs?
Old 10-29-2011, 08:36 PM   #7
Nogas's Avatar
G
The plugs / connectors that plug into the 2 large holes in the lipo (marked + and - ) are called banana plugs. They are basically 4.5mm bullets. in the top of the bullet plug is a cup that the wire is soldered into. If you cut a groove in the side of the cup to allow the wire to come out of the bullet at a right angle, it will allow you to route the wires out the standard battery cable recess in the door.
Tekno RC
MBX6e V4 Tekno
MBX6Te V4 Tekno
Old 10-29-2011, 10:39 PM   #8
Gotchya. Thanks for that. Tomorrow I'll be doing some work on it. Thanks all for your help. I'm sure I'll post more if I run into troubles.
