Tire Removal (Step By Step, How To)
I often come across threads asking the same question about tire removal. So, the last time I did a set of mine, I took a few pics to show how to do it with ease. This is my method and it works for me.....
First, use a utility knife and cut the old tire off. Discard tire carcass and foam. Don't cut yourself!
Next, place the wheels in a bucket of acetone. I put about 2 inches in a 2.5 gallon bucket with a sealed lid.
The acetone evaporates real fast so you want to make sure the bucket is sealed tight. Let the wheels sit for at least 24 hours. I usually wait about 2 days before I pull mine out.
After 24-48 hours, pull the wheels from the bucket and peel away.
These wheels are straight out of the acetone (48 hour soak) with no scrubbing of additional glue. As you can see, they're ready for use right away.
Make sure to put the lid back on the bucket. Next time you need to remove tires, just use the dirty acetone that's already in there!
This is great and all but a lot of people want to be able to save the tires also, and these tires don't look like they can be reused.
Wow thats easy !
If the tires are old and worn out why whould you want to use them again thats the point of what he was doing.
For racing im talking about.
I have truggy tires so thats a great thing to do saves $$.
tjek URC.com he got a nice video on it and u can leave out ´cutting the tiers up and reuse them again
Good how to. I would reuse those foams though. Good closed cell foams will last a long time and are also expensive. You can get tires without the foams for cheaper than with the foams. If you are cutting the tire off anyway save those bad boys. If you don't want to save the foams I wouldn't bother cutting the tires off. The acetone will work just as good without cutting them but closed cell foams soaked in acetone swell to about 5 times their original size. I have seen it!
Nice job CHIZZLE...
If you are trying to save the tires or foams, you can use the same method, but elevate them from not touching the liquid and the vapors will still react with the glue and you will be able to remove them. I use a smaller container from walmart like a a salad container that has a raised insert in the bottom.
I had just bought new tires and mounted them on 2wd wheels. Then decided to run 4wd instead. I threw the whole tire in and let soak overnite in acetone. Popped em off and reused tires and inserts. No problem.
I always cut my tires off first because it allows the acetone to penetrate from both sides of the beads. Plus, it allows fours wheels to sit down in the acetone at the same time. I've tried the elevated method without cutting the tires off but it doesn't work near as good. With that you still have clean the bead of glue remnants and it takes a longer soak before they start to peel off. With the above method, they literally fall off when you pull them out of the bucket.
And if you're careful with the knife, the foams can be reused no problem.
Just did the soak
Old thread, I know, but I did just soak my tires in Accetone and wanted to give an update. I put four tires in a pan, then I poured a bag of blue aquarium rocks on the tires, then I poured in Accetonento the top of the tires. I put wood on top of the container. After 24 hrs I was able to remove one side and remove the inserts. Soaking again to get the other side free.
Tires: AKA Rebars
Foams: Red AKA foams
Wheels: AKA wheels
Old CA looks to be black, got these in a trade and the glue started cracking
AKA red foams did not react to the Accetone, but they were also dry when I took them out.
Tires: AKA Rebars
Wheels: AKA wheels
