Team Associated RC8.2e Thread >
Like Tree6Likes
Old 10-17-2013, 10:37 PM
  #5416
Default Some images of my monster / ebuggy rig
Some images of my new project =D love this machine!
Attached Thumbnails Team Associated RC8.2e Thread-_igp9987.jpg   Team Associated RC8.2e Thread-_igp9986.jpg   Team Associated RC8.2e Thread-_igp9977.jpg   Team Associated RC8.2e Thread-_igp9975.jpg
weblet86 is offline
Old 10-17-2013, 10:46 PM
  #5417
vandalzzz's Avatar
seems your front upper arms are installed in backward direction
vandalzzz is offline
  #5418
KOULLIT's Avatar
Hi weblet86,
It seems that your front upper arms are reversed, or flipped !
Bye !
KOULLIT is offline
Old 10-17-2013, 11:08 PM
  #5419
yeah i installed them that way to get more clearance for the badlands. dosent seem to make much difference since i don't race just bash it.
weblet86 is offline
Old 10-18-2013, 12:04 AM
  #5420
KOULLIT's Avatar
Hi weblet86,
Can you tell us what is your body, name and brand ?
Thanks !
Bye !
KOULLIT is offline
Old 10-18-2013, 06:09 AM
  #5421
Blacktiger355's Avatar
Trader Rating: 81 (99%+)
Originally Posted by homershoots View Post
Nice man! You running aka impacts?
Tires are AKA Enduro's. About half worn down.
Blacktiger355 is offline
Old 10-18-2013, 10:07 AM
  #5422
Ahh ok they look a lot like the impacts I'm running, they work awesome especially once the track gets rubbered in.
homershoots is offline
Old 10-18-2013, 02:42 PM
  #5423
is this normal? when your rc is off you can't turn the wheels to the right. i mean it's crazy i can't get the wheels to turn. but as soon as i turn on the esc and my transmitter the servo and wheels center up without a problem.
i didn't notice this before. i just think it's weird that the servo locks up in one direction
Yello is offline
Old 10-18-2013, 07:59 PM
  #5424
Mine did something similar to this. I couldn't turn it by hand in one direction but I could turn it in the other. The torque going in the direction I couldn't turn is was MUCH less than the torque going in the other direction. The torque was so bad in that direction that the servo wouldn't even return to center with the car sitting on the floor, it had to move a bit.
AE said I had a bad servo and are sending a replacement.
Markah is offline
Old 10-19-2013, 08:45 AM
  #5425
Brodenburg's Avatar
This happened to me a few times right before my JR9100T servo bit the dust.
Brodenburg is offline
Old 10-19-2013, 08:58 AM
  #5426
Cridd's Avatar
Trader Rating: 16 (100%+)
Yes bad servo happenend to me on my sons T4.2. Aggravating, to move wheels had to power up.
Cridd is offline
Old 10-19-2013, 11:54 AM
  #5427
KOULLIT's Avatar
Hi,
In a recent post, I asked you some questions about the wear of the shaftpins, in all the differentials outdrives of our RC8s. The removing of the pins...
I have posted on the nitro section first, the pictures of my parts, so I will show you here, electric drivers, what I'm talking about :
I'm trying some 7075T6-OUTDRIVES with a CVA blade system on every differentials of the RC8 :
Then, I'm actually trying some 7075T6-OUTDRIVES, and the question is the reliability.
I made many runs myself with my own old RC8, and my blades are able to make 10 or 15 runs before to "wear down" (rear train), and many more on the other drive trains. The problem : the way I "wear down" the parts is not a law for everybody, we have to make some better test runs...
The gold versions are hardcoated, and the rear ones are just hard anodized, this was for the tests.
Of course I will produce only the Hardcoated version, but I made some tests with the Delrin (POM H) for the CVA Blades material, so maybe I will try an other material.
These parts are lightened parts : 4,30 grammes/unit.
And the CVA blades, already knowned in other scales, allow a smoother transmission.
The only thing is the run time before to change the CVA blade, if some drivers, on a track with a lot of grip, have to change the CVA blade every 6 packs (electric) or after 1 hour of run (nitro), it's a big problem for me and the users.
My personal tests are good, I can make ~ 20 packs on each train before to see a real "wear down".
Now, you (everybody) have to tell me what do you think about a lot of 12 CVA Blades that I'm planning to sold 6USD ? Do you think it's a good deal or not ? Then this will cost 3USD each time a driver wants to change every CVA Blades ( on the 3 differentials ).
The parts will be available for every RC8, but the outdrives for the center diff will be only available for the electric version, because of the brake discs... (not available for nitro).
(Then for front and rear for nitro, and for the 3 differentials of electric versions)
Maybe have you already seen my 3D projects here, but today I would like to produce my first parts. I have many parts to show you but I wanted to begin by this one, because the system can be applied on every brands.
But it's the only one system I will show you before to produce something :
I think it's an interesting sytem, but you need to "convert" all your shafts to use it, and I don't really know if you are "ready" to use this system or not, with the necessity of change the cva blades frequently ?
So, what's your opinion ?
Thanks,
Bye !
KOULLIT is offline
Old 10-19-2013, 12:43 PM
  #5428
do they make a difference in handling compered to a worn stock outdrive/completely new stock outdrive?
Cody227 is offline
Old 10-20-2013, 05:12 PM
  #5429
vandalzzz's Avatar
Does anyone have issue with slope between gearbox halves and outdrive bearings? My buggy has, both fr and rr, freeplay about one millimeter each, and seems it was here from beginning.
Old 10-20-2013, 06:20 PM
  #5430
My servo died on me yesterday. So, I guess it's a fact: If your servo locks in one directoin when it's off, then it's only a matter of time...
Will a 1258 servo with futaba-style 25 spline servo fit in an RC8.2e?
First off, I don't even know what the "1258" is referring to - since there's a 1258 Savox, a 1258 Turnigy servos, etc..
Anyone care to enlighten? I've already made a purchase but now I'm worried it won't fit in the Rc8.2.
Thanks.
Yello is offline
