Team Associated RC8.2e Thread
#3768
hay guys/ what are you fast guys using for diff oils. I am runing 555 thanks guys. need som help
#3769
what are you guys running for diff oils? I am running 555 thanks
#3771
I've tried a bunch of combinations but always end up back with 5-5-5.
#3772
I like a little thicker in the front so I am running 7-5-3 right now. I may go up to 7 in the middle.
#3773
Do the new kits have a bronze chassis is that it ?
i have had a new chassis and its bronz/gold coated .
#3774
I asked AE this question directly. It is a hard anodized coating similar to the ft shocks. It is to resist wear from dragging across track surface. The reason for two models is is a running change, all new kits will include updated anodized chassis. Old black chassis I'd being phased out.
#3775
Hi guys, just wanted to let everyone know that I recently got the AE Carbon Shock Towers for my RC8.2e and weighed them to see what the difference is over the stock FT aluminum towers.
A pair of CF towers is 1/2 oz. lighter than the aluminum ones.
IMO, that's a very low weight savings to cost ratio (It was about $80 for the pair) but they do look nice and seem very stiff.
Just some information I wanted to pass along.
#3777
No, not yet. I only get to bench race the thing until springtime when the 1/8 tracks open up.
#3778
#3779
TSMiley -
3 RX8s, all doing the same thing on the one 4s battery?
1) Have you tried using a different battery and if so, was it also 4s?
On any or even all three of the RX8s, do you normally use 4s batteries?
The reason I ask, is it sounds to me as if that may not be the case, and if I'm correct, the LVC is not set for 4s batteries. When LVC is not set correctly, the Rx8 will not arm. You'll still get power to the receiver though, so this is why the servo and PT still operate.
#3780
