The Official Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread with Tekin included >
Old 10-16-2011, 05:44 PM
Suspended
Default The Official Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread with Tekin included
There has been lots of buzz about this truck. We all speculated on what and when it was going to be released. Well now we know the Losi 4wd will be based off the Ten T chassis. TEN-SCTE 4WD Short Course Rolling Chassis
Type:4WD Short Course Rolling Chassis
Scale: 1/10
Length: 21.34 in (524mm)
Width: 11.65 in (295.8mm)
Wheelbase: 13.15 in (334mm)
Weight: 6.75 lb (3.06 kg) Fully loaded ready to race
Tire Type : Eclipse SCT
Kit/RTR: Rolling Chassis
Shock Type: Aluminum, Coil-over, oil-filled
Body Clear Polycarbonate SCT
Functional mud flaps with Losi logo
Oversized 12mm anodized, threaded shocks
12mm wheel hexes
Secure battery straps
Battery tray accepts multiple types and sizes of packs
Heavy-duty, 4mm tie rods with captured ends
Beadlock-style SCT wheels with rings
Front and rear sway bars included
Eclipse™ Short Course truck tires
Secure radio box to protect the receiver
Simple adjust, aluminum motor mount
Lightweight black anodized aluminum chassis
Needed to Complete
550-sized Brushless System (Motor and ESC)
1/10-scale Steering Servo
2S LiPo Battery Pack and Charger
2-channel Radio System
Polycarbonate Paint
550 Motors
Viper R/C VST XL 4.5-6.5
Viper R/C VX4 R52, R45
Novak Ballistic 550 4.5-6.5T
Novak HV 4.5-5.5T
Fantom Fusion 1 & 2 550’s
Speed Passion V10 3.5R-5.5R
Speed Passion V2 5.5R
Team EPIC Monster Horsepower 550
Team Epic 4x4 Short Course Monster Horsepower 4.5t
LRP X12L Short Course Sensored Brushless 550 Motor
Orion Vortex 10 2800kv (best on 3S)
Castle Creations 1415 2400kv
1/8th Scale Motors
No Data
540 4 Pole Motors
Tekin Pro4
Castle Creations 1410 1Y 3800kv 4 Pole
Viper R/C VX4 R52 / R45
SC 4600 Tenshock 4 Pole
Gearing recommendations with 40T spur (2 Pole motors)
4.5 550's - 13-16T pinion
5.5 550's - 14-17T pinion
6.5 550's ??
Castle/Neu 4 Pole motors
Castle 3800kv - 13-18T pinion
Castle 2400kv - 17-23T pinion (20 tooth and beyond you need the ERC motor mount).
3MM Mod 1 Bore Pinions for CC 1415 & 1410 motors
Recommended ESC’s
Tekin RX8
Viper R/C VTX10R
HobbyWing SC8 ESC (part# HW-SC8)
Mamba Monster
Novak Kinetics
LRP SPX8
LRP Sphere Comp TC Spec w/fan
Speed Passion GT2 PRO
Stock shock oil f/r - 30w from the factory. Stock Diff's come filled with grease. When disassembling the diff housings, be careful when removing the screws. They have been known to be in tight and require a 1/16th sized hex.
Stock spring rates
Black springs front/rears
The current fronts are 3.6, 3.9, 4.3
The current rears are 3.0, 3.3, 3.6
Spring rates for LOSB 2959 Front set
Green - 3.6
Blue - 3.9
Black - 4.2
Purple - 4.5
Spring rates for LOSB 2963 Rear set
Red - 2.7
Orange - 3.0
Silver - 3.3
Green - 3.6
Losi Updated Spring Sets
Shock Piston sizes:
#1 0.95mm | #2 1.00mm |#3 1.05mm | #4 1.10mm | #5 1.15mm
Diff housing screw size (for people who have stripped the screws and want another option) Four screws - 2.5mm 45 pitch 10mm. HPI has some screws that work part# Z449 , they are M2.5x12mm 2mm longer than stock but the holes are deep enough in the diff housings.
Diff fluid starting points.
Indoor blue groove 5-7-3 (Front/Center/Rear)
Indoor blue groove 5-5-3 (Front/Center/Rear)
Outdoor med bite 3-3-2 (Front/Center/Rear)
Lunsford SCTE Titanium Turnbuckle kit
2 - 4mm x 65mm Titanium Turnbuckles (Front Camber)
2 - 4mm x 68mm Titanium Turnbuckles (Steering)
2 - 4mm x 70mm Titanium Turnbuckles-Long Thread (Rear Camber)
Losi 8ight 2.0 Ti Turnbuckles: (Work with the SCTe) - Thanks Chris A!
Screw for suspension arm to shock mounting
Screw kit replacements
252-piece high grade alloy steel socket head screw kit - Tony Screws
Bearing sizes for the entire truck
LOSA6907 5 x 8 x 2.5 Ball Bearing 4each Steering
LOSA6947 5mmID x 11mmOD x 4mmW Sealed Ball Bearings 4 each Front and Rear Diff Pinions
LOSA6954 5 x 10 x 4 Sealed Ball Bearings (clutch bearings for Ten-T)
LOSA6956 12 x 18 x 4 Sealed Ball Bearings 6each F/R/C Diff outdrives
LOSA6957 10 x 15 x 4 Sealed Ball Bearings Plastic Retainer 4ea Inner Hubs
LOSA6958 6 x 12 x 4 Sealed Ball Bearings with Plastic Retainer 4ea outer Hubs
Bearings Avidrc.com
Factory Parts Listing
BondoNutz how to get your SCTe below 6lbs thread
Parts Weight
Losi stock battery tray: 2.8oz/79g
Losi stock rear hubs: 7g
Losi aluminum rear hubs: 10g
DER-310-L XD Rear Skid Plates: +5gr
LOSB3575 Front/Rear HD Lightened Outdrive Set: -8gr (a pair)
LOSB3576 Center HD Lightened Outdrives: -4gr
TLR4000 Tuned Flex Lightened Chassis: -69gr
LOSB2426 Rear Torque Rod, TLR Chassis: +5gr
Losi Stock DIff Cups (Thank you 8ight for the pictures!!!)
Losi Hop up Lightened Outdrives (Thank you KingdomRacer for the pictures!!!)
Center Diff Outdrives
Front & Rear Outdrives
Stock Losi hinge pin holders (Thank you 8ight for the pictures!!!)
Losi aluminum hinge pin holders
SNR Graphite hinge pin holders SNR's Part Listing for the SCTe -
BCE Racing - Losi SCTe upgrade chassis
Battery Weights
Orion 90c 6500mAH lipo's (bullet style) are 286 grams
Info about the Proline Flo-tek
Hey guys just got the proline flo-tek body for my scte and it has the dimples marked for the truck allready. The front is marked wrong you will actually drill the front body mount holes in the spot marked for the sc10 (second back from the front of the truck) and not the third mark. Just letting someone know before they just go drill the post holes. Luckily I eyeballed it before i did mine. This body is sweet looking.
DE Racing Wheels:
Blitz sized bodies fit with the least trimming. SC10 bodies fit but require more trimming.
PM me with any TLR SCTe win and I will post you here.
TLR Winter series @ Revelation Raceway -1st place - Shane Flores (AKA SEF) Ten-scte
2nd place- Devon Boisvert (AKA D-money) Ten-scte
Losi SCTE WINS" Sliver State Short Course Championship at 702 in Vegas
1st. Kyle (the ICEMAN) Johnson - Losi SCTe
2nd. Steve Antill - Ae SC10 4wd
2011 Golden State SCT championship
Karl Rolf - TQ and second in the A main in 4x4 expert (Losi SCTe)
Anyone who has been reading the thread knows the diff pins on the first shipment of trucks have diff pins that are to soft for brushless power. Losi has updated the pins in the second shipment. If you suspect you have the older pins, contact Horizon Hobby (877) 504-0233, they will send you new pins free of charge. We don't need you to post about how pissed you are, we get it... It happened to all of us.
Diff Pins
The diff pins in the truck have been fixed in the seconds shipment of trucks. If you would like aftermarket pins, I suggest using Chrispins ([email protected]) or visit his forsale thread located here - Steel Diff Bushings (Made by Chris A!) - Diff pin length
24 mm long 3mm thick and the grove in the middle is 3mm long and 1.5mm deep
Other Diff gear alternatives
OFN21003 - gears and pins (only using the small bevel gears and pins..)
KYO96775 - Kyosho bevel gear washer/shims or any 4x10x.15 washers
You will need two of those behind each bevel gear to help things mesh properly. At least that's what mine needed.
Pull the losi or AE pins out and toss em on the side.. Same with the Losi gears, tiny washers and aluminum bushings and replace with OFNA gears, Kyosho washers (or equivalent). The shafts are a touch too long. You will need to trim equal amounts from both ends of the pin. It is nothing major, it isn't so much that you need to cut it off with a wheel. Just a touch on the grinder or dremel tool and all will be good.
For those of you who have done or are doing the OFNA gear replacement, here is another great reason..
OFNA Hard Anodized Aluminum CNC 4mm Cross Pin Diff Axles
$9.25 @ A-Main Part# OFN30774
Chassis droop screws
Keep an eye on your chassis where your droop screws hit the stops. The small screws will chew down the chassis over time and cause premature wear. You can prevent this by installing 4-40 x 4mm Droop Screws (part#LOSA6253) I highly recommend you use a tap set on the screws. If you screw up the holes it's impossible to fix. USE THE TAP!!! Tap & Drill Set 4-40 tap
Servo Saver
From the factory check your servo saver for tightness, we have seen this comes loose and causes steering issues. Red loctite seems to be the fix, blue loctite just doesn’t hold over time.
OEM Hop-up Parts
Front/Rear Lightened Outdrives Part # LOSB3575
Replacement inserts for the adjustable hinge pin supports...they are in stock and are LOSB4114
Center Lightened Outdrives Part # LOSB3576
Technical Questions: Questions about this product should be directed to Horizon Hobby's Product Support department.
Horizon Hobby, Inc.
ATTN: Product Support
4105 Fieldstone Road
Champaign, IL 61822
Email: [email protected]
Support Phone: (877) 504-0233
Fax: (217) 355-1552
MXRacer1 is offline
Old 10-16-2011, 05:48 PM
Suspended
Let me know if there is anything you guys want me to include, I wont discriminate.
MXRacer1 is offline
Old 10-16-2011, 05:52 PM
Trader Rating: 70 (100%+)
Pretty ballsy to copy another post and start a new thread with it - especially with under 10 posts to your name.
Krafcik is offline
Old 10-16-2011, 06:00 PM
we have a thread like this already .
http://www.rctech.net/forum/electric...ck-thread.html
dany5 is offline
Old 10-16-2011, 06:06 PM
BmainStar's Avatar
It is a joke because of the talk on the real scte thread bout the Tekin not being on the first page info
BmainStar is offline
Old 10-16-2011, 06:16 PM
Suspended
Whats in a name? I didn't just copy it, I added Tekin to it.
MXRacer1 is offline
Old 10-16-2011, 06:44 PM
alvinsmith75's Avatar
Trader Rating: 38 (100%+)
Yall are something else. Because of this thread I will, from now on, only buy Viper products!!!!!!!!!!!!! VIPERVIPERVIPERVIPERVIPERVIPERVIPERVIPERVIPERVIPER VIPERVIPERVIPERVIPERVIPERVIPERVIPERVIPERVIPER
alvinsmith75 is offline
Old 10-16-2011, 09:50 PM
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
x 1000000000 people seem to amaze now days. high school drama at its best and making a storm in a cup of water.
ps. mxracer i see you got copy and paste skills!!
Mr.juarez is offline
Old 10-16-2011, 09:55 PM
Cult Racing's Avatar
Trader Rating: 42 (100%+)
not so much with pictures lol
Cult Racing is offline
Old 10-16-2011, 09:58 PM
SaladFork's Avatar
Wonder who started thread formatting on RCT and keeping the front page up to date.
SaladFork is offline
Old 10-17-2011, 02:13 AM
cwilkinson's Avatar
Saladfork Soupspoon butterknife chopsticks your avatar cracks me up it's such a porn queen
cwilkinson is offline
Old 10-17-2011, 06:45 AM
rcguy76559's Avatar
Trader Rating: 22 (100%+)
rcguy76559 is offline
Old 10-17-2011, 08:33 PM
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Thumbs up Tekin
Include Tekin in everything..... It's the American way!
XXXDad is offline
Old 10-17-2011, 08:41 PM
Pvd brett's Avatar
lmao... i have a strange feeling this thread will go nowhere...
while tekin is good stuff im amazed at how you people cry because it is not written in text on the front page of someone elses thread.... Big friggen woop... if you are crying about it you obviously know about the product so who cares if its on there or not. Unless you are a team driver or ceo of tekin its not your place to argue because its not on the front page. Grow up, i run a tekin setup in my scte and i will run tekin in my future rides but i dont give a flying rat turd whether its reccommended by an rctech user or not.
Pvd brett is offline
Old 10-17-2011, 08:47 PM
It's not about us - it's about Joe Newbie. If he goes to an "official" thread he should either see all possible options on the front page or none. He shouldn't be "pushed" towards a specific product by a rep. Otherwise be upfront and say "The official Losi SCTE thread sponsored by Viper R/C"
Krafcik is offline
