Mounting Rims on tires? >
Old 10-02-2011, 11:26 AM
I Wheelie A LOT's Avatar
Trader Rating: 15 (100%+)
Default Mounting Rims on tires?
Hey guys, does it matter at all which way i mount my rims (All-star rims) on my trenchers? Thanks
I Wheelie A LOT is offline
Old 10-02-2011, 12:00 PM
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
no they are not directional .
BashemSmashem is offline
Old 10-02-2011, 01:02 PM
D-Rek07's Avatar
What about Pro-line Scrubs?
D-Rek07 is offline
Old 10-02-2011, 01:19 PM
ovalracer1m's Avatar
Trader Rating: 29 (100%+)
Those are directional.
ovalracer1m is offline
Old 10-02-2011, 02:00 PM
Ok sweet, just in case how do i know if a tire is directional or not?
Old 10-02-2011, 02:32 PM
D-Rek07's Avatar
I think tires are directional if you turn it around then it looks different, but if you turn it around and it looks exactly the same, then it isn't directional.
D-Rek07 is offline
Old 10-02-2011, 02:47 PM
My trenchers on both sides were completely the same, but when i mounted the rims they looked different. Are they directional?
Old 10-02-2011, 02:55 PM
RatsacK's Avatar
Trader Rating: 21 (100%+)
A lot of the time the rubber is directional but the rims often don't matter.
RatsacK is offline
Old 10-02-2011, 02:59 PM
K, thanks
Old 10-04-2011, 08:44 AM
Speedytech7's Avatar
Lightbulb Dirt Hawgs Reversed
I noticed that my B4.1 performes a load better when I have the tire tread pattern backward on one of my wheels. It grips the turns with ease, but, when the treads are "correct" they seem to slip more. BTW, I race on clay and loose soil. However, these poor tires just get eaten alive on blacktop because the rubber is just too soft.
Speedytech7 is offline
Old 10-04-2011, 08:53 AM
As tires wear the leading edge of each lug gets rounded off and they loose a little bite , when you switch them left too right you turn the tire around and the rear of each lug is now the leading edge and hasnt had the sharp edge worn down yet so it has more bite for a little while .
Old 10-05-2011, 07:30 AM
Thumbs up Thanks
Ok, I had wondered why that was happening thanks BashemSmashem.
