need help on elec 1/10 buggy >
Old 09-29-2011, 03:12 PM
Suspended
Angry need help on elec 1/10 buggy
I have a b4.1 with ko propo bsm 1.5 and thunder power 8.5 with 5000 mah 2 cell 40c and my radio is spectrum dx 3.0 when Im driving its find untill I get around 150 feet then I get nothing no steering or throttle what could it be batteries in radio are good please help!!
belliso is offline
Old 09-29-2011, 04:00 PM
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Low batteries can cause range issues , but I would look at your reciever first , make sure the antenna wire on the reciever isnt nicked or broken and make sure its fully extended (doesnt need to be outside the body).
BashemSmashem is offline
Old 09-29-2011, 04:32 PM
RatsacK's Avatar
Trader Rating: 21 (100%+)
It's your radio. I had the same issue with a Spektrum DX2.0. Spektrum are known to have pretty average range...
RatsacK is offline
Old 09-29-2011, 04:36 PM
nikkon's Avatar
Trader Rating: 251 (100%+)
Had the same issue when I had spektrum dsm radio systems around my house. Wasn't sure if it was radio (tried 3 different ones with same issue), receiver (tried 4 diff ones) or interference from something around me. I switched to a FHSS radio and have never had the problem since.
nikkon is offline
Old 09-29-2011, 04:58 PM
Suspended
what radio should I get that isnt to expensive or should i try a different receiver ?
belliso is offline
Old 09-29-2011, 04:59 PM
Suspended
never had this issue before when all my electronics where in my xray 808 buggy
belliso is offline
Old 09-29-2011, 05:13 PM
D-Rek07's Avatar
I don't think your electronics are prejudiced.
D-Rek07 is offline
Old 09-29-2011, 05:16 PM
IDK about all that ? My Spektrum DX3s can drive it at least 4-500 feet away without a problem , granted its hard to even tell which way its pointed at that distance ....
Old 09-29-2011, 06:32 PM
Suspended
what else do you think it could be or would it be radio or receiver what is most likely to go bad?
belliso is offline
Old 09-29-2011, 07:19 PM
cnelson3's Avatar
Trader Rating: 66 (100%+)
antenna. put it up the best you can.
cnelson3 is offline
Old 09-29-2011, 08:25 PM
Suspended
what is a better system spektrum or 2.4 fhss
belliso is offline
