Old 11-19-2004, 05:37 PM   #1
Default Diff oil vs shock oil
Is diff oil the same as shock oil except for weight? A lot of racers are using light weight grease like Lucas #2 red in the rear diff to gain steering. The problem with that is that you have to regrease the diff gears every 5 races or so. Why couldn't I just use shock oil instead? Like 70 wt. They're both silicone oil.
slrguy is offline   Reply With Quote
Old 11-24-2004, 07:11 PM   #2
MikeAbrams's Avatar
It sounds like you're referring to 1\8 buggy setups, is that it?
If it is, even though I've never owned a 1\8 buggy, I'm pretty sure it isn't all the same oil. In the simplest way I can say, diff oil is thicker than shock oil.
MikeAbrams is offline   Reply With Quote
Old 11-24-2004, 07:38 PM   #3
Trader Rating: 20 (100%+)
slrguy,
I assume also you are talking about 1/8 th scale set ups. 70wt oil is very light compared to 1000 wt , 5000wt, 10,000wt that is primarily used in buggys. A basic set up on diffs is 5000wt front, 7000wt center, 1000wt rear . 70wt would very thin compared to these numbers. Are they putting the Lucas grease in the front, center, or rear diff ???
Brandon Powell is offline   Reply With Quote
Old 11-25-2004, 09:49 AM   #4
Originally posted by Brandon Powell
slrguy,
Yes, 1/8 scale setup. The Lucas grease goes in the rear diff in place of diff oil. The diff is not packed with it, only the gears are given a good coating. I've tried this and it indeed does give more steering and works great on a track with lots of tight turns. The only problem with this is that the grease needs to be changed every 4-5 races because it slings off the gears.
Sportwerks makes silicone diff oil in 100, 300, 500 and 700 wts. I was thinking that silicone shock oil would be a better solution than grease because you can fill up the diff and it would last longer than grease but still keep the effect.
Diff and Shock Oil *cheap* skengines R/C Items: For Sale/Trade 3 05-12-2008 09:24 AM
How often should shock&diff oil be changed? DirtRacer Nitro Off-Road 3 01-09-2008 09:30 PM
Large Oil Lot Diff/Shock/Air/After Run Oil tmaxxking R/C Items: For Sale/Trade 12 10-18-2007 10:49 PM
Diff & shock oil Joe Tanto Nitro On-Road 0 12-18-2006 03:41 PM
Diff and Shock Fluid chumanji Nitro On-Road 1 08-18-2005 10:00 PM
