Old 11-15-2004, 03:59 PM   #1
Default Diff oil recommendations?
I'm running 1/8 scale buggy with front/center/rear diffs. I need a recommendation for a track with lots of slow, tight turns and a short straight. I'm currently running 3k-font, 5k-center and 500 (.5k)-rear trying to get as much steering as possible. The buggy (Mayhem Pro) came stock with (5k, 5k, 1k). While this proved to be a good compromise, it wasn't allowing enough turning on a really tight track. What's everyone else running?
slrguy is offline   Reply With Quote
Old 11-15-2004, 04:43 PM   #2
OvalEvader's Avatar
Send a message via AIM to OvalEvader
3-5-2 will give you awesome steering, but will be hard to control with the 2k in the rear.
OvalEvader is offline   Reply With Quote
Old 11-15-2004, 05:58 PM   #3
I'm new to all this! Could you explain why 2k in the rear would be hard to control? What is happening? Does 2k in the rear cause the rear to lock up too quickly when powering out of a turn causing the rear to slide out too quickly? I found some silicon diff oil at 500 wt which I put in the rear diff hoping that would keep the rear from sliding out when powering out of a turn. Is that correct?
losi xxxt ball diff change to a 1/10 desert truck diff newbie2 Electric Off-Road 49 12-13-2010 08:49 PM
NTC3 Complete ATD Diff, diff nut, pivot ball socket caps Judge Joe Brown R/C Items: For Sale/Trade 2 05-09-2008 10:18 PM
ESC recommendations WayzOfTheCore Rookie Zone 7 04-11-2007 07:48 PM
[B]Fioroni Center Diff And Front Diff And Ofna Torsion Diff For Hyper 7[/B] Imdadundada7 R/C Items: For Sale/Trade 22 08-07-2006 11:11 PM
XRAY T1FK04, XRC 4.0mm Chassis, One-Way, Diff, Hudy Spring Steel Diff, and MORE! BobbyDoyle R/C Items: For Sale/Trade 10 08-18-2005 04:38 PM
