Traxxas Stampede Forum >
Old 12-08-2004, 03:09 PM
  #61
never lift's Avatar
go with the pede it looks better and you can make it true to scale like a real monster truck . + it 's racable to so it does two roles racer & basher .
never lift is offline
Old 12-10-2004, 02:03 PM
  #62
never lift's Avatar
has anyone cut the back end on there truck for cooling the motor or do you use heat sinks
Old 12-10-2004, 04:49 PM
  #63
DFroyd's Avatar
Definetly cut away the portion of the trans case above the motor. Cheap motor cooling that takes very little time/effort
DFroyd is offline
Old 12-10-2004, 06:31 PM
  #64
never lift's Avatar
yea it was pretty easy i was just wondering if anybody else has done this mod yet .
Old 12-10-2004, 09:10 PM
  #65
Trader Rating: 24 (100%+)
I have also done that. In addition to add some protection to the motor endbell I have added an RPM B/T 3 rear bumper/motor guard. Took a bit of shaving to fit and a pair of self tapping screws but it worked slick. I have also drilled out the stock rims using a 27/64 or .422 drill bit to save on rotating mass. That helped out too.
Red Z is offline
Old 12-11-2004, 12:04 AM
  #66
hoppy6698's Avatar
Any pics of these mods?
hoppy6698 is offline
Old 12-11-2004, 12:21 AM
  #67
I'll try to get some and mail them to you.
Red Z is offline
Old 12-12-2004, 09:49 PM
  #68
never lift's Avatar
hey red z how many holes did you drill in each rim
Old 12-13-2004, 12:45 AM
  #69
I just enlarged the small holes that came already in the off-white rims. I started with a bit that was just a bit bigger than the stock hole and worked up to a 27/64 or .422 size bit. It seemed to help. I'd have a pic to email but the USB on my CPU is on the fritz.
Red Z is offline
Old 12-13-2004, 08:04 PM
  #70
never lift's Avatar
no problem thanks for the info on the rim drilling that's my next mod
Old 12-13-2004, 10:15 PM
  #71
I found a way to use CVD's. part number is on the way. I was using some random cvds i had around.
Seems to increase speed a bit on the oval. Not sure how this will work off road, tho..
Red Z is offline
Old 12-14-2004, 10:57 AM
  #72
never lift's Avatar
keep me posted on the numbers i'm in the middle of doing the rim mod .
Old 12-14-2004, 11:27 AM
  #73
When you do the rims, make sure that you don't hit anything but the hole you want to drill. A buddy of mine tried this and wasn't paying attention. He drilled the holes out, and the rest of the rim all the way through from front to back!
Red Z is offline
Old 12-14-2004, 11:36 AM
  #74
never lift's Avatar
ok thanks for the heads up but attention to detail is everything
Old 12-14-2004, 02:30 PM
  #75
Note:
The CVD mod killed my diff. I guess its back to the plastic shafts.
Red Z is offline
