Spare parts
Spare parts
I am new to the SC10 and I wanted to know what spare parts I should stock in my Pit box. The car is an RTR, fully stock and I wanted to know what issues I will run into if I put a 3S 11.1V 5000 Mah 40C LiPo battery in it. Are there parts I am going to completely tear up?
Thanks for any info
Thanks for any info
I would start off with an extra spur gear, extra front arms, extra ball cups and ball studs, front wheel bearings( which also fit the rear hub carrier ), 25 and 30 wt shock oil, and a shock rebuild kit. It mainly depends on if you're going to the track with it or just messing around. If you're bashing it, that 3 cell lipo should be a blast.. If you're bashing, I'd get an extra front bumper, bumper mount, and shock tower as well... This is a very basic list.
With the assumption that you're bashing it with the three cell:
Front and rear arms
Turnbuckles
ballstuds
ball cups
Hinge pins
Spare bearings
Extra screws
Body posts
Body clips
Body mounts (where body posts attach)
Extra spur gears
Axle pins
Shock rebuild kit
Shock oils and black grease
If you are going to be running the truck purely for bashing, I strongly recommend looking into getting the RPM front and rear arms and bumper. You will also need the Team Associated GT2 Hingepins to use the RPM front arms.
Front and rear arms
Turnbuckles
ballstuds
ball cups
Hinge pins
Spare bearings
Extra screws
Body posts
Body clips
Extra spur gears
Axle pins
Shock rebuild kit
