The Official Atomik / Venom V2MR RedEdition® 2WD Race Spec Buggy >
Like Tree2Likes
Old 02-14-2014, 08:17 AM
  #706
kaiser's Avatar
Originally Posted by thechuckles8910
So..... pretty new to this forum.
Was wondering if this would be a good first race buggy?
Never really have raced before just bashed.
Thanks,
CJ
NO. in my opinion none of the cheaper options for 2wd buggy are good forst race cars. i do like this car but i've been tuning race cars for decades. there's alot of trial and error with these "off brand" cars. it will frustrate a new racer to deal with the little issues these cars have.
i'd go for an associated b4 or b5 as a first racer. right out of the box they are stable, reliable cars.
kaiser is offline
Old 02-16-2014, 11:04 AM
  #707
I completely understand that, and I thank u for responce, but I dont hve that kind of money Anything else u suppose might work?
Thanks,
CJ
thechuckles8910 is offline
Old 02-16-2014, 11:10 AM
  #708
R/C Tech Elite Member
TIME MACHINE's Avatar
Trader Rating: 74 (100%+)
If anyone needs any V2MR parts, check out ebay. Just type "huge V2MR lot".
I've listed a bunch of new and used parts in one big lot for cheap. I'm cleaning house and would like them to go to someone who appreciates this buggy only the way RCtech members can.
TIME MACHINE is offline
Old 02-16-2014, 12:27 PM
  #709
rcrickie's Avatar
Trader Rating: 60 (100%+)
for those who would like a base line for a mid motor set up here is what i have done with mine and it is pretty close. I can run with b5's, rb6's,cento's and schumacher KR's with this set up.
rcrickie is offline
Old 02-16-2014, 12:39 PM
  #710
jk racing's Avatar
Trader Rating: 20 (100%+)
Rickie, on your inside camber links (front & rear), are you running any spacers at all? I didnt see it on the set up sheet.
Also, your using Schuey BB springs?
jk racing is offline
Old 02-16-2014, 01:07 PM
  #711
rcrickie's Avatar
No spacers on any of the camber links. Yes the Schumacher BB springs. They fit on perfectly and are slightly longer than the stock and the tapper on the bottom allows for use of the stock spring cups.
rcrickie is offline
Old 02-16-2014, 02:22 PM
  #712
Taz_S's Avatar
any way you can get parts number for the springs and Servo Horn, i want to me sure i got the right parts. and thanks.
Taz_S is offline
Old 02-16-2014, 02:40 PM
  #713
rcrickie's Avatar
spring info:
U3679 Big Bore Spring; Med - 4.0 pr
U3684 Big Bore Spring; Long - 2.5 pr
kyosho servo horn info:
LA221HB hard servo saver
rcrickie is offline
Old 02-16-2014, 10:17 PM
  #714
Taz_S's Avatar
I run at the same track as Hooter and run the V2MR also. The B4.2 rear hexs still keep the car leagal width. The front b4.2 hexes work well too, just be mindfull that diffent offsets of wheels used the sholder on the stub axle could protrude past the nut seat. With the rear b4.2 hexes this is not an issue.
The car is a solid platform with some items that need addressed out of the box. The servo horn is very brittle and breaks easily, use a Kyosho hard servo horn for the RB6 it has the correct offset and height.
So what needed to make the front like the b4.
http://www.amainhobbies.com/product_...-Wheel-Hex-Set
http://www.amainhobbies.com/product_...ock-Set-SC10RS
http://www.amainhobbies.com/product_...Front-Axle-Set
Taz_S is offline
Old 02-17-2014, 07:52 AM
  #715
rcrickie's Avatar
You can switch to the b4.2 to run the 12mm hexes. I would say that if u do go to hexes I would use the atomik gambler steering knuckles and axles. That way you keep the same steering geometry.
rcrickie is offline
Old 02-17-2014, 10:32 AM
  #716
Taz_S's Avatar
http://www.atomik-rc.com/Steering-Kn...category=76913
http://www.atomik-rc.com/Front-Axle-...category=76913
cool thanks
Taz_S is offline
Old 02-17-2014, 01:13 PM
  #717
jk racing's Avatar
Be aware, the Gambler uses different size hinge pins, the V2MR pins WILL NOT work...without finesse
Old 02-17-2014, 03:01 PM
  #718
MOmo's Avatar
I used the following with no modification.
asc7922. 30deg caster
Asc9880 steering block hex
jco2169 axle conversion for hex
jco2135. 12mm clamp hex front
works great. My update coming soon.
Momo
MOmo is offline
Old 02-19-2014, 06:30 PM
  #719
Taz_S's Avatar
Momo
So what front wheel should i get. To stay close the stock width?
Taz_S is offline
Old 02-20-2014, 06:09 PM
  #720
Momo
what are the size/part # bearings that would need to be used with this set-up?
dynastorm is offline
