The Official Atomik / Venom V2MR RedEdition® 2WD Race Spec Buggy
#316
I ordered the Losi springs and I've been looking over my old B4 for parts i could scavenge to swap to the VMR2. I should have enough AE O-rings to build my shocks.
Do you happen to have the part # for the losi rear hub carriers, or can one use the AE ones? I have a spare set of the Aluminum ones 0.0degree hubs from my B44.1/B4.2 laying around and I thought about using it.
What motor are you using and what gearing? Might make this one similar to my B4.2 and run a 8.5, but Mid configuration.
I'll try and get back to building it tonight.
MOmo
#317
Congrats!
MOmo
MOmo
Ive ran the past couple of weeks using a Venom "Red" 17.5, geared 75/31.
I usually run a Venom 7.5 geared 83/22.
#322
SO I started building the Mid- trans setup and even on the MID configuration, I still have some Spur wobble.
I was going to use the AE Pads and the AE plates, but maybe I'll see if Stock will work. I did go to a 72t spur (AE) thinking maybe there was warp in my AT/VN spur, but again i have a slight wobble. I thought others had stated they updated to AE plates, but maybe I was wrong. AE Pads maybe?
So I was using:
-AE Slipper Plate (Vented)
-AE Slipper Pad
-AE Slipper Spring/Nut / Retainer
And I get wobble. I even tried the stock Plate (trans side stock plate, Vented plate on the outer with AE Pads, and still Wobble.)
Kinda frustrating.
I did bring my B4.X to work and plan to play around with the front C hubs/axles/ etc.
MOmo
So I was using:
-AE Slipper Pad
Kinda frustrating.
MOmo
#323
I have mine in mid-motor and I am using the stock plates, spring, spring retainer, JConcepts spur and AE high torque pads and I have no wobble in the gear.
#327
So I used Stock Plates, stock spring and retainer and AE pads, and have no more wobble (FINALLY) though i was hoping to use the vented slipper.
Got to swapping some spare B4 front c hubs and knuckles and noticed one was cracked, so I'll have to get another set.
So for gearing, i too went with a Kimbrough 72T spur. debating on a simple 3500kv for starters or possibly going 10.5 or 8.5 to start. Thoughts on gearing? Heard people say that the gear cover could be a problem on mid motor setups and also will I be able to get a big enough pinion on it to make power?
MOmo
MOmo
#328
My gear cover is in the box. I think you have to put that on before you install the transmission. I tried jamming it on there and gave up pretty quick.
Blake
Blake
#329
Anybody,
Are these true 12mm shocks? Looking at shock piston options.
Blake
Blake
