The Official Atomik / Venom V2MR RedEdition® 2WD Race Spec Buggy >
Old 04-22-2013, 06:02 AM
  #286
kaiser's Avatar
Originally Posted by MOmo View Post
Quick question about using AE pads. Did you use the stock slipper plates and AE pads or switch everything to AE?
I'm converting mine to mid and giving it a shot since several racers are going mid motor at my track and my 4.2 is already R motor.
Is anyone trimming or noticing flashing inside the case, either the R motor or M motor case? Thinking I might shave it down. also noticing I still seem to have a high spot when the trans spins around, did anyone else?
Who has a mid motor setup?
Momo
what papa said, idler shaft is a touch too long. i still haven't shaved mine down yet. i just didn't crank down on the gearbox case screws.
the "high" spot goes away after break in.
i'm using an ae spur/ae pads but stock atomik plates.
kaiser is offline
Old 04-22-2013, 10:11 AM
  #287
GeekSpeed's Avatar
Guys, quick question again:
I am assuming to run mid-motor, I need to have a shorty pack. What about rear-motor? Can I run a standard sized pack?
GeekSpeed is offline
Old 04-22-2013, 10:35 AM
  #288
kaiser's Avatar
yes. in rear motor you can run all three, regular, shorty and saddle.
in mid you can run shorty and saddle.
kaiser is offline
Old 04-22-2013, 10:39 AM
  #289
GeekSpeed's Avatar
Thanks!
I am trying to decide between this and a Tamiya TRF201
Old 04-22-2013, 10:45 AM
  #290
kaiser's Avatar
it's a cool car, it's not perfect but it's a solid option.
i'd take it over a trf due to price, and cool factor. the shocks are really nice on the atomik. i'm digging it for sure.
kaiser is offline
Old 04-23-2013, 10:10 AM
  #291
zeakemedia's Avatar
Trader Rating: 95 (99%+)
It showed up a day early so the build will begin! Gotta work tonight so I doubt I get it done.
Blake
zeakemedia is offline
Old 04-23-2013, 11:56 PM
  #292
zeakemedia's Avatar
Anybody have some tips building the CVD's? Could use a little help. They just aren't going together smooth at all?
Blake
Old 04-24-2013, 04:52 AM
  #293
Papa88's Avatar
Blake
Thats weird mine went together good just use some black grease on the joint and loctite on the set screw,i like how they have a notch in the pin..
Papa88 is offline
Old 04-24-2013, 05:14 AM
  #294
kaiser's Avatar
Blake
mine didn't either. i dremeled them and polished them but they are still a little notchy. i'm going back and forth with atomik trying to get replacements.
kaiser is offline
Old 04-24-2013, 12:12 PM
  #295
zeakemedia's Avatar
Just about done but I gotta go to work. I think I have it all figured out, maybe. I'm hoping to get a little practice this Sunday.
Blake
Old 04-24-2013, 12:15 PM
  #296
kaiser's Avatar
how did you make out with those cvd's? did you do anything to them?
kaiser is offline
Old 04-24-2013, 12:57 PM
  #297
zeakemedia's Avatar
I worked at them for a while this morning. I am hoping they loosen up after the first run.
Blake
Old 04-25-2013, 12:30 AM
  #298
zeakemedia's Avatar
Only have electronics left.
Blake
Old 04-25-2013, 04:32 AM
  #299
kaiser's Avatar
looking good.
what front axels do you have on there?
kaiser is offline
Old 04-25-2013, 08:44 AM
  #300
zeakemedia's Avatar
Those are JConcepts front axles inside AE steering arms.
Blake
