60 amp esc.
60 amp esc.
Is tha difference in a 60 amp ESC and a 35 amp ESC Very noticable? I realize that the 60 is gonna b better, but how much better. Im new to this hobby and am just learning tha ropes. Im bout to put a 35 amp esc with a 4270kv brushless on a EXT2. Started off right, huh?
If your motor is within spec for both ESCs the difference is so small you would likely not notice. But if your motor consistently pulls more current than the 35A can keep up with then it will not last long and you will need a higher spec'd ESC like the 60A.
as stated the motor will make the difference. If its one of the finned can 380 rotor motors, more than likely you won't have any problems in the light evader. If it is a true 540 size 3650 motor, you should go ahead and go with the 60a. That's no much esc if you are running in grass or off-road.
