How do you protect your motors from the dust? >
Old 08-06-2011, 03:59 PM
Pulse_'s Avatar
Default How do you protect your motors from the dust?
Hello,
I'm going for a long endurance race very soon in 1/8 brushless and would like to protect my T8 1400kv motor from the dust. I was thinking about using silicone sealant to close the little openings, what do you guys use?
Pulse_ is offline
Old 08-06-2011, 10:03 PM
ovalracer1m's Avatar
Trader Rating: 29 (100%+)
I would not plug the holes as they are vent holes to help with cooling. I see epic now offers a motor diaper for 540 motors but don't know about having them for 550 motors. I personally wouldnt worry about the dust and run it. I ran a tekin t8 in dusty conditions for a while (used for a couple of seasons) With 0 issues.
ovalracer1m is offline
Old 08-06-2011, 10:09 PM
slashracer111's Avatar
Trader Rating: 25 (100%+)
There is nothing mechanical in the motor. It's just magnetic fields that turn the motor shaft. So nothing mechanical = nothing to go wrong. Just blow it out with air.
You don't have to do anything different. I run all my motors in the dust no problem.
slashracer111 is offline
Old 08-07-2011, 04:45 AM
Pulse_'s Avatar
How can the holes be vent holes if they are against the motor mount when the motor is mounted? Aren't they just other threads for mounting the motor in 3 different positions? I felt concerned about the bearings.
Pulse_ is offline
Old 08-07-2011, 04:48 AM
RatsacK's Avatar
Trader Rating: 21 (100%+)
I think he assumed the holes were on the can, not the end where it mounts. Shouldn't your mount basically cover all those holes anyway?
RatsacK is offline
Old 08-07-2011, 04:49 AM
neobart's Avatar
Unless the motor has a built in fan, I would plug it up as best I could.
neobart is offline
Old 08-07-2011, 05:04 AM
Chris K's Avatar
Trader Rating: 46 (100%+)
One word - Outerwears
Chris K is offline
Old 08-07-2011, 05:08 AM
Pulse_'s Avatar
Not all of them on my RCMonster motor mount. I must be over thinking then, I don't wanna miss something for this race so I'm asking myself questions I never did before
Pulse_ is offline
Old 08-07-2011, 06:56 AM
dug44's Avatar
Desiged and built with dirt in mind..... Think you should make sure those tires are the best glued tires you ever did.... Hope you win, or at the very least. Walk off the driver stand with a smile....
dug44 is offline
Old 08-07-2011, 08:24 AM
You could put a condom around the motor to keep the dust out.
x60Driver is offline
Old 08-07-2011, 09:25 AM
BMenard17's Avatar
Trader Rating: 88 (99%+)
HAHA, hopefully he uses magnums or he will have to switch to a 540 can.
BMenard17 is offline
Old 08-07-2011, 02:10 PM
brsilva's Avatar
If you are concerned about your motor replace the bearings now and then after your race. If you think your bearings are going to fail after a race that (I think) is going to last an hour or 2 you have bigger problems with that motor. The condom could work but you will be reducing the cooling effect of the aluminium that makes up your can, if you get it too warm you could have melted condom on your motor.
brsilva is offline
Old 08-09-2011, 06:12 AM
Pulse_'s Avatar
The motor is almost new so no worries .
Just a good video from Randy Pike from Tekin, you might have seen it already
+ YouTube Video
He doesn't seem to bother about the dust
Pulse_ is offline
