DYNAMITE STARTUP TOOL SET question
I just got this(very cool) Dynamite startup tool set that has a universal handle and comes with all the extended nut drivers, hex and phillips bits most RC's would need.
For anyone that has experience with this tool:
Are the bits supposed to just slide out when you pull on them? Or is it supposed to lock and not go into or come out further from the handle?
Mine only slides out of the handle when I pull on it but it doesn't move into the handle once locked in(if you push in on the tip of the bit).
So I was thinking maybe this is for changing the bits out faster?
Anything helps,
thanks.
Anything helps,
thanks.
I have the same set and mine is the same way. From others I have talked to they are all like that. I dont know why. Personally I would prefer it locked the tool bits in. I dont know how many times I go to pull the tool out of the screww and the whole damn bit comes out of the handle. But hey, for $25 it's not a bad set, espcially for starters.
