TLR 22T Thread
#811
#812
#813
Can someone explain to me to me what makes this truck so great besides the aluminum chassis for and the mid or rear engine mount setup??
I havent done alot of research into them yet, But I'm thinking of selling my Hpi E-firestorm and buying one of these. I own a Losi Ten-scte with a rx8/ pro 4 4600kv and It's my first Losi and there hands down my favorite out of Traxxas and Hpi that ive owned.
#815
I have a mini-8ight on back order (supposed to be for xmas), but Horizon tell me they are gonna be January now
We had the 22's earlier than the guys in the states (sorry chaps) kinda hoping for the same deal with the 22T
#816
I hope the UK's shipment it not fair behind, I need something to build over xmas!!
C'mon now, say something witty.
#817
The guys at Norcal hobbies used to love it when i called them "wankers"
#818
No sign of postman yet keeping my fingers crossed
#819
Depending on your driving preference or track conditions, the 22T Truck will deliver the configuration you need. For the first time, TLR is providing both rear- and mid-mount motor configurations in a single kit.
Complete Kit
Build the 22T Truck from the ground up so you know and control the entire assembly process to your exact specifications.
2.5mm Hard-Anodized Aluminum Chassis
The precision-machined 7075-T6 2.5mm aluminum chassis is hard-anodized for increased durability and a great look.
Gull Wing Suspension Design
This design allows the overall height of the front tower to be much lower and lowers the 22T's center of gravity, which improves handling.
12mm Big Bore Shocks
Smooth the ride, tame large jumps and tune suspension performance with these oversized shocks with bladder compensators.
Adjustable Front Kick (20-25°)
The 22T's front end has best-in-class clearance that allows for improved handling. It gives you more clearance when you enter and exit steep jumps.
Plus it's tunable via a shim from 20 to 25 degrees.
Adjustable Caster (0, 3, 5, 10°)
The 22T's caster can be adjusted in 0-, 3-, 5- and 10-degree* increments via the spindle carriers.
* 0-, 3-, and 5-degree spindles are optional.
Racing Wheels
These new wheels were designed specifically for the 22T Truck. We are including 2 complete sets without tires so you can pick the tread and compound you need to dominate your track. The 22T uses the same front and rear wheel via a 12mm hex.
#821
Does anyone know if HPI wheels will fit ?
#823
#824
I really want one of these trucks, I saw a video on youtube from losi showing off the truck, I love the shocks and the chassis.
Would I be be able to run my Turnigy Nano-tech 2s lipo's i got some hardcase and softs in mid motor config?
Also what Spur gear's are available ?
Anyone know what the price may be?
Think im selling my Hpi and picking up one of these when they come out.
#825
Will pick this up when my Lhs gets them in
