TLR 22T Thread
#5944
I'm very happy with mine, I have updated the shocks and running the exotech steering. For a new kit I'm not sure how they would improve it. Maybe a 3 gear tranny for those running 17.5 MM
#5945
Oh and maybe side pods and battery mount that let you run shorty battery side ways
#5946
This was discussed in the 22 thread. It would require a complete redesign of the drivetrain of the truck to work. When I ran for Durango and tried the 3 gear mm setup, did not like it at all. I agree that the truck in its current form is very good. Just too heavy for stock. Maybe a good milling out of the chassis to lighten it up.
#5950
You can try softer front spring. A little more front camber (go to 2 deg). Lower the front ride height a little.
Driving a 2wd vs a 4wd car is different. 2wd will be a little bit more of a handful as you don't have all wheel drive to get you out of trouble but give some of those tweaks a try and see if it gives you what you are looking for. Does not sound like it was too far off to take a big swing at it.
Today I finally got to try out this change - 6 months later (I've been a bit busy and only got to the track 2 days since July). I dropped the front ride height by 2mm (to 27mm) and it made all the difference! Suddenly there was a lot faster turn-in. I haven't tried the camber or spring changes yet.
As the turn in seems quite sudden, I think I might dial it out a little with Expo.
Thanks again, and this is what I always tell my friends about the Losi/TLR products - you drivers frequent the thread and are so willing to help out with some pro tips!
#5951
does anybody know the correct turnbuckle length for the new steering bell cranks for this truck thanks
#5955
http://www.ebay.com/itm/tlr-22t-/191...item2c9478da48
http://www.ebay.com/itm/Losi-TLR-Twe...item19f9bb1dde
