TLR 22T Thread
Old 10-27-2014, 08:33 PM
  #5761
Jack302's Avatar
Trader Rating: 22 (100%+)
Questions??
Originally Posted by XXXDad View Post
I have the new bell crank do I use the whole kit? on the 22T
http://www.tlracing.com/Products/Def...odID=TLR231027
^Part number TLR231027?
How do you like it?
Jack302 is offline
Old 10-28-2014, 06:14 PM
  #5762
Jack302's Avatar
Questions??
Originally Posted by Frank Root View Post
You do not use the spindles.
Which ones?
Jack302 is offline
Old 10-29-2014, 06:29 AM
  #5763
Pdub66's Avatar
Originally Posted by Jack302 View Post
Which ones?
I think i saw somewhere that you can use the 22T spindles with the new bell crank. I put one on my 22 2.0 and like it, will upgrade the 22T here soon with this feature.
** Looked around and you can use the 22T spindles with the bell cranks.... www.petitrc.com under the 22T setup site, Phend's setup that shows his pictures has the 22T spindles, w/angled ball cups on the bell crank and reg ball cups on the outside.
Pdub66 is offline
Old 10-29-2014, 08:38 AM
  #5764
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Thumbs up
Works great but pushed a little so I used more digressive front tire,
Yes to stock spindle, Mine works well but I did have some push. So I run a more aggressive tire and compound .
XXXDad is offline
Old 10-29-2014, 09:41 AM
  #5765
muggy427's Avatar
Who think there will be a 22t in the works soon I know the class is dead but with Team Associated Coming out with the centro i think we will see a 22t 2.0 soon also with phends big win at nats I know the tlr guys said there wont be a new one but they also said that about the 22-4
muggy427 is offline
Old 10-29-2014, 01:18 PM
  #5766
Pdub66's Avatar
Will be a bunch of used TLR 22T 1.0 used for sale then if that happens. According to sources w/TLR and Team Drivers it isn't going to happen. I'd hate for them to be wrong you know.
Our local class is growing right now in the ST class, we had zero last year for indoor season, and we currently have 5+ at the start of the winter indoor season...
I like the feel of my 22T.. But if the loacl tracks start picking back up you never know what could happen...
Pdub66 is offline
Old 10-29-2014, 01:36 PM
  #5767
Pauly6401's Avatar
Trader Rating: 52 (100%+)
When I was at OCRC Raceway last weekend, the guys behind the counter said that there was an Associated T5 and Losi 22T 2.0 in the works when I complained about the lack of new stadium trucks coming out (I was there running my Losi XXX-T CR).
So who knows if that's the truth, but a lot of team drivers and reps practice/race/hang out there. One can dream!
Pauly6401 is offline
Old 10-29-2014, 02:07 PM
  #5768
muggy427's Avatar
I think that between the two biggest brands in rc cars tlr and associated were to release a new stadium truck the class would pick up again. Also the tire makers don't help it any too
muggy427 is offline
Old 10-29-2014, 02:08 PM
  #5769
muggy427's Avatar
Whats a good setup for this truck for med bite indoor clay
muggy427 is offline
Old 10-29-2014, 04:50 PM
  #5770
Jack302's Avatar
Questions??
Does this work better or the same as the exotek one?
Also where did you get those gold washers under the screws? product number?
Jack302 is offline
Old 10-29-2014, 06:05 PM
  #5771
Braxamus's Avatar
is it possible to convert the buggy into a truck if so where can I find a list of the parts?
Braxamus is offline
Old 10-30-2014, 08:52 AM
  #5772
XXXDad's Avatar
Arrow Go buy a good used 22T and Race or update your Truck to 2.0 spec
It is nice to want something new, but in all reality the standard 22T is still super competitive. For very little, upgrade your 22T to a 2.0 model.
New shock parts are available with the machined parts and also the improved shock shafts. Then the New steering bell crank. What more can thy change? Think about it. Go get a used 22T and race.
I agree with TIRES, because I run outdoor on loose tracks and it leaves allot to be desired.
http://www.petitrc.com/setup/losi/Se...wentyTwoT.html
Try here^
Exotek gets a little sloppy form the input I got from a TLR team member here in Florida. But still an option. I like to stick with the new Bell Crank , remember you don't use the spindle and you need a 3.5x70mm turnbuckle to make it work .
http://www.amain.com/Search?cID=5321&s=gold+washer
Gold Washers^
Don't bother it's too costly just buy and new used truck and go race.
XXXDad is offline
Old 10-31-2014, 08:44 AM
  #5773
Jack302's Avatar
Questions??
http://www.amain.com/JQ-Products-Ful...t-Gold/p208393
^Will this set fit the 22T screws?
Jack302 is offline
Old 10-31-2014, 10:25 AM
  #5774
Casper's Avatar
Trader Rating: 34 (100%+)
http://www.dynamiterc.com/Products/D...ProdID=DYN8510
Dynamite makes nuts as well
http://www.dynamiterc.com/Products/D...ProdID=DYN8540
And wheel nuts. (disclaimer non serrated!)
http://www.dynamiterc.com/Products/D...ProdID=DYN8570
Casper is offline
Old 10-31-2014, 11:33 AM
  #5775
Jack302's Avatar
Questions??
http://www.amain.com/ProTek-R-C-TLR-...-Motor/p300808
^Anyone use the ProTek R/C TLR 22T Titanium Screw Kit?
Jack302 is offline
