TLR 22T Thread
Old 05-04-2014, 06:13 PM
  #5611
Point me in a direction for a setup for a small tight low bite track
horsedog is offline
Old 05-04-2014, 07:04 PM
  #5612
tony montana's Avatar
Trader Rating: 75 (100%+)
ST is coming back big in my area as well. Yesterday they had a full heat and more guys are planning on getting them and I am one of them. SCT is all but dead around me and Im loving every minute of that lol.
tony montana is offline
Old 05-04-2014, 08:17 PM
  #5613
forwardonly's Avatar
Finally got my 22T to turn some decent laps. I had been struggling with far too much steering and not near enough rear forward grip or side bite. I added some weight to the rear and changed the shock package to keep weight transfer towards the rear. I want to go up in oils to calm the entire truck down. Our new track layout has some tricky jumps and my truck is springing off the jumps. Cool to watch, but not good for lap times. I think if I calm both ends of the truck down, it will settle down and fly a bit lower so I can push it a bit harder. However, I finally turned similar lap times to my 22b which is pretty dialed to our track.
forwardonly is offline
Old 05-09-2014, 08:21 AM
  #5614
SoCalMX's Avatar
Thinking of buying a 22T used to add to my small stable (see below). I see a lot of rollers out there, what is a good motor/esc combo. I would keep it rear motor so I can use the same 2s stick lipos I use in my SCTE 2.0, I have 6 batteries.
SoCalMX is offline
Old 05-09-2014, 08:37 AM
  #5615
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
For bashing or racing?
Frank Root is offline
Old 05-09-2014, 08:46 AM
  #5616
SoCalMX's Avatar
Guess that would help! It would be racing, indoor clay. Maybe a stock setup? I am not sure what is a more popular class, that's if I even actually race it, might just run the track but never bash.
SoCalMX is offline
Old 05-09-2014, 09:00 AM
  #5617
Casper's Avatar
Trader Rating: 34 (100%+)
Depends on what classes your track runs. Stock truck seems to still be popular on the club scenes from what I have seen. Mod truck class tends to be hard to come by unless it is a large event. With that being said I would go with a stock motor setup.
Casper is offline
Old 05-09-2014, 09:03 AM
  #5618
SoCalMX's Avatar
Cool. Being I am buying a roller, what is a good stock motor/esc to buy? Sorry, I am fairly new and don't know what to look for.
SoCalMX is offline
Old 05-09-2014, 02:42 PM
  #5619
SoCalMX's Avatar
Also, I was told the 22t is no longer in production, true?
SoCalMX is offline
Old 05-09-2014, 03:01 PM
  #5620
TLRacing
Frank Root's Avatar
True. We still make all of the parts, and are not done racing truck
Old 05-09-2014, 03:04 PM
  #5621
jeffyrc's Avatar
Thumbs up
Wish there was a like tab to click. Hoping for a 2.0 version.
jeffyrc is offline
Old 05-09-2014, 03:50 PM
  #5622
Stevomatik's Avatar
I got a question for frank... With the new bell crank system coming out would those new spindles fit on the 22t arms?
Stevomatik is offline
Old 05-09-2014, 04:12 PM
  #5623
TLRacing
Frank Root's Avatar
No, you will need to use the existing truck spindles. With a standard sized servo, you can get to full lock, but it will be hard (if not impossible) with a low profile servo.
Old 05-09-2014, 04:48 PM
  #5624
I would recommend the Novak Vulcan 17.5 w/ Pulse, Impact or GTB3 depending on future needs.
LAGuy is offline
Old 05-09-2014, 08:15 PM
  #5625
SoCalMX's Avatar
Cool. Looking at one that has a Orion Stock Spec ESC, D3 17.5 Trinity motor, and a Savox servo 4096. Hope parts wont become scarce...
SoCalMX is offline
